楼主: seuxiaoj
[求助] ICC floorplan经验
发表于 2017-8-5 02:39:47 | 显示全部楼层
回复 109# zw1035961900
     how to hand place IO pad cells in ICC design planning,I tried reading in the design.DEF with pre-defined locations in component section
but did not work
please help
发表于 2017-8-5 02:43:11 | 显示全部楼层
回复 91# yangzai1236
but did not work
please help
发表于 2017-8-14 15:39:31 | 显示全部楼层
回复 38# 无乐不作
    骚操作
发表于 2017-8-17 14:30:54 | 显示全部楼层
mark .
发表于 2017-8-28 14:50:23 | 显示全部楼层
thank a lot
发表于 2017-9-2 15:49:08 | 显示全部楼层
小白想问下,这么找data flow?找前端要吗?
发表于 2017-9-4 15:22:17 | 显示全部楼层
回复 16# torlies
    感谢分享~~!
发表于 2017-9-5 03:17:31 | 显示全部楼层
回复 1# seuxiaoj
memory 放周边只是原则,主要取决于 1. pin location; 2. logic hierarchy; 3. logic connections (用 fly line 显示)
发表于 2017-9-9 22:20:29 | 显示全部楼层
using padding
发表于 2017-9-21 17:21:26 | 显示全部楼层
水一下
GMT+8, 2025-11-17 01:19 , Processed in 0.021907 second(s), 5 queries , Gzip On, Redis On.
