查看: 6045|回复: 11
[求助] MOS管饱和区迁移率
发表于 2012-8-7 16:09:57 | 显示全部楼层 |阅读模式
MOS管在饱和区时,如果漏极电压VDS保持不变,栅极电压VGS变大,
此时,沟道中电子的迁移率如何变化
发表于 2012-8-7 16:24:43 | 显示全部楼层
回复 1# elovu5256
   在Vgs不是很大时,迁移率不变
   当Vgs越来越大,迁移率会变小
 楼主| 发表于 2012-8-7 16:49:40 | 显示全部楼层
回复 2# feynmancgz
    为什么呢 是由于晶格散射吗
 楼主| 发表于 2012-8-7 16:49:43 | 显示全部楼层
回复 2# feynmancgz
    为什么呢 是由于晶格散射吗
发表于 2012-8-7 17:05:33 | 显示全部楼层
二级,多级效应
发表于 2012-8-7 17:12:03 | 显示全部楼层
Mobility reduction due to vertical field
 楼主| 发表于 2012-8-7 20:49:47 | 显示全部楼层
回复 6# semico_ljj
    能解释一下吗 谢谢
 楼主| 发表于 2012-8-7 20:52:17 | 显示全部楼层
回复 7# hezudao
    can you explain it more clearly ? thanks
发表于 2012-8-7 21:05:33 | 显示全部楼层
回复 5# elovu5256
   When Vgs-Vt is very hihg, carriers are attracted to interface states and other imperfections at the Si-SiO2 interface due to the high, vertical, electric filed between the gate and the channel. This causes a reduction in carrier mobility
 楼主| 发表于 2012-8-7 21:59:46 | 显示全部楼层
回复 10# feynmancgz
    so the reduction of mobility is the result of scattering, right?
GMT+8, 2025-9-13 08:40 , Processed in 0.017359 second(s), 4 queries , Gzip On, Redis On.
