查看: 36871|回复: 64
Synopsys CoCentric System Studio(CSS) 2010.12
发表于 2012-6-15 08:46:57 | 显示全部楼层 |阅读模式
System Studio is a high performance, model-based signal processing algorithm design and analysis tool. It combines the industry’s best simulation performance with high modeling efficiency plus seamless integration into chip implementation design and verification flows. Leading communication and multimedia companies rely on Synopsys’ System Studio and DSP model libraries to address their system-level design needs by getting to results faster. There is a good chance that your cell phone comes with a System Studio-designed modem.
注:只有软件,无license,下载请慎重。
 楼主| 发表于 2012-6-15 09:10:33 | 显示全部楼层
软件官方:
http://www.synopsys.com/Systems/BlockDesign/DigitalSignalProcessing/Pages/SystemStudio.aspx
 楼主| 发表于 2012-6-15 09:14:54 | 显示全部楼层
two parts for linux
        CRC                size            filename
3002326022        199802880        css_vE-2010.12_common.tar
2133083754        912793600        css_vE-2010.12_linux.tar
发表于 2012-6-15 09:29:53 | 显示全部楼层
回复 4# milosky
   please continue!  Thank you very much!
发表于 2012-6-15 09:48:54 | 显示全部楼层
回复 4# milosky
   顺便加上64呗
发表于 2012-6-15 13:14:24 | 显示全部楼层
非常宝贵的资料,不知道这个和spw哪个更好,synopsys今后以哪个产品为主?
发表于 2012-6-15 21:31:21 | 显示全部楼层
cali01,you can use synopsys sss keygen for crack it
发表于 2012-6-15 22:40:16 | 显示全部楼层
回复 7# milosky
   楼主,顺便加个amd64呗
发表于 2012-6-16 10:11:50 | 显示全部楼层
回复 10# speakeet3
发表于 2012-6-17 03:58:38 | 显示全部楼层
How to configure cocen to run in windows?
GMT+8, 2025-12-4 02:54 , Processed in 0.020156 second(s), 6 queries , Gzip On, Redis On.
