楼主: milosky
Synopsys CoCentric System Studio(CSS) 2010.12
发表于 2012-6-29 04:40:49 | 显示全部楼层
Thanks very much for the answer!
I am trying to run in windows and currently I use SCL 10.9.3.
For better controlability  I used lmtools and defined a server and entered the Lic file that I have created and started to read and start the server. Every thing is OK to this step but When I try to drag ccss_exec.exe from gui folder to a command window for executing I get this message "The desired vendor daemon is down". For reducing interference I unistalled VMware because of unnecessary network adapter.  I also view the log inside the lmtools and it shows that the License is valid.
Does all of these problems are related to:
1- my wrong execution of the tool (by dragging the tool to the command window)?
2- Wrong version of SCL?
3- what are the necessary environment variable in windows? Is LM_LICENSE_FILE or CCSS_KEYS variable enough?
Below is my final error message. I see in the task manager that snpslmd.exe file is executing but I see the error again.
What is your solution?
How should your sent ccss file be exexuted? Should I change it to bat file and only click or what?
Thanks very much again!
发表于 2012-6-29 09:28:29 | 显示全部楼层
try it in linux ,
in windows , when i type ccss in cygwin ,popup a window,but can't do anything.
发表于 2012-6-30 09:53:27 | 显示全部楼层
如何解决这个问题???????????
发表于 2012-6-30 22:13:17 | 显示全部楼层
The versions 11.2 till 11.4 in WIN, tries to detect the license file but say that Packages (you can see them inside the license file) are not supported anymore but 10.9.3 detects the file. when CCSS is invoked it says that lmgrd is down. I really do not know why. I think some files should be cracked.
So someone help please!
发表于 2012-7-5 22:23:16 | 显示全部楼层
好资料!收藏了!!
发表于 2012-7-5 22:28:40 | 显示全部楼层
有没有破解文件分享??
发表于 2012-7-6 22:49:31 | 显示全部楼层
这个软件是干什么用的
发表于 2012-7-7 06:32:59 | 显示全部楼层
Can you please tell how to use it?
发表于 2012-7-10 07:51:40 | 显示全部楼层
请大侠做一份破解文件吧。
发表于 2012-7-14 12:56:48 | 显示全部楼层
如果有哪位高手破解了,还希望另外开贴讲解,谢谢!
GMT+8, 2025-12-4 03:36 , Processed in 0.028807 second(s), 5 queries , Gzip On, Redis On.
