楼主: milosky
Synopsys CoCentric System Studio(CSS) 2010.12
发表于 2012-6-17 14:59:27 | 显示全部楼层
回复 16# ald_syn_cad
   i had setup the environment  yet, need install cygwin , visual studio 2008 (maybe newer version is ok),mingw-gcc . but always report license error. i use the same one license file in RHEL6 , it work smooth.
╮(╯_╰)╭
发表于 2012-6-17 16:00:35 | 显示全部楼层
Can you please send your using license? I proceeded with EFA but I have the same problem. I think we need to patch some files like Processor Designer.
More info (Complete Procedure):
http://www.synopsys.com/Support/LI/Licensing/Pages/default.aspx
发表于 2012-6-17 18:33:37 | 显示全部楼层
I used SCL 1.9.3 (win version) and the integrity of lic file was verified by sssverify.exe correctly but I got below message (The desired vendor daemon is down) . Notice that server line has been blurred.
发表于 2012-6-17 20:40:34 | 显示全部楼层
My Previous error message was removed by simply restarting the system. Note that "Start Server at Power Up" in the config service tab of LMTOOLS.exe (By installing SCL 19.9.3) should be checked before restarting.
After doing the above operations this time I got the following message. Can someone help?
发表于 2012-6-17 21:14:10 | 显示全部楼层
回复 20# ald_syn_cad
   The same issue
发表于 2012-6-18 07:32:15 | 显示全部楼层
怎么还有windows版本???
发表于 2012-6-28 21:51:29 | 显示全部楼层
Can someone please post the working crack and configuration script?
发表于 2012-6-28 22:09:19 | 显示全部楼层
回复 23# ald_syn_cad
   Pls ur hostid ,attached package contains a linux cshrc and a win bashrc file ccss.rar (750 Bytes , 下载次数: 82 )
发表于 2012-6-29 01:11:16 | 显示全部楼层
Thanks snk88 for providing this. But my main problem is with the cracking. First let me ask you a question. Did you succeeded in running in Linux and windows?
If yes can you please ask my some questions please?
1- Which version of SCL are you using both for Linux and Windows?
2- what did you enter in site ID field when you installed SCL?
3- Are you using both the wireless and Lan cards?
4- Are you using WMware?
5- which Ethernet ID you entered? Your LAN or Wireless?
6- In windows you use LMTOOLs for creating Server or that is not needed?
7- Where should exactly these bashrc files should be copied and how they will be invoked?
8- Do we need to use SFK for Cocentric? If your answer is yes what is the code?
9- After installing which file should be executed? in GUI folder?
10- How can I solve the problem When it says The desired vendor daemon is down?
11- Can you please send your using EFA keygen and a license sample?
12- And any thing you think that would be helpful.
I have used lots of Synopsys tools but Cocentric does not work. Maybe because of having multiple Cards on the system.
Thanks so much!
发表于 2012-6-29 01:23:30 | 显示全部楼层
1,scl11.2,11.3,11.4,all ok
2,not needed
3,only lan
4,vmware 8+ RHEL6.2,and physical machine
5,lan
6,not needed
7,should change some paths
8,no
9,ccss, it seems a perl script file
10,no
11, i've no idea too.
GMT+8, 2025-12-26 04:56 , Processed in 0.023633 second(s), 6 queries , Gzip On, Redis On.
