查看: 5090|回复: 3
[求助] 帮我看看这个计数器为什么总是提示Syntax error near "process"
发表于 2012-5-21 10:42:19 | 显示全部楼层 |阅读模式
entity data_gen is
PORT( clk: in std_logic;
   rst: in std_logic;
   countut integer range 0 to 255
end data_gen;
architecture Behavioral of data_gen is
begin
  process(clk,rst)
  variable counter:integer range 0 to 255;
  begin
   if (rst = '1') then
     counter <= (others => '0');
   else if (clk'event and clk = '1') then
     if (counter=255) then
      counter <= 0 ;
     else
      counter <= counter+1;
     end if;
   else
     counter <= counter;
   end if;
   count <= counter;
  end process;
end Behavioral;
发表于 2012-5-21 11:25:32 | 显示全部楼层
你的counter定义的是integer,赋值语句不能用<=,而是:=
 楼主| 发表于 2012-5-22 10:29:29 | 显示全部楼层
回复 2# 回家上自习
    library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity data_gen is
   rst: in std_logic;
   count : out integer
end data_gen;
architecture count_255 of data_gen is
begin
  process(clk,rst)
  variable counter:integer :=0 ;
  begin
   if (rst = '1') then
     counter := 0;
     if (counter = 255) then
      counter := 0 ;
     else
      counter := counter+1;
     end if;
   else
     counter := counter;
   end if;
   count <= counter;
  end process;
end count_255;
我如果给PROCESS加上一个标号P1,进程结束 时end process p1;就会报两个错误, Syntax error near "process".Syntax error near "count_255".去掉进程的标号以后只有一个Syntax error near "process".
不知道是为什么总提示process的语法错误,求高人指点!
 楼主| 发表于 2012-5-22 10:53:38 | 显示全部楼层
回复 3# 乐烁橙
错在这里:elsif (clk'event and clk = '1') then
GMT+8, 2025-12-23 18:53 , Processed in 0.019803 second(s), 5 queries , Gzip On, Redis On.
