查看: 3989|回复: 2
[求助] 朋友们,遇到过ATPG 跑SPF的时候出现这种错误吗?头疼啊
发表于 2012-3-15 22:43:31 | 显示全部楼层 |阅读模式
Error: miscounted items (Force clocks has 53 values instead of 107 in procedure "multiclock_capture"). (V10-1)
Error: miscounted items (Force clocks has 53 values instead of 107 in procedure "allclock_capture"). (V10-2)
Error: miscounted items (Force clocks has 53 values instead of 107 in procedure "allclock_launch"). (V10-3)
Error: miscounted items (Force clocks has 53 values instead of 107 in procedure "allclock_launch_capture"). (V10-4)
各位请帮忙啊,一般原因在哪里,如何解决,多谢
发表于 2014-4-4 10:19:03 | 显示全部楼层
请问LZ问题解决了吗,怎么解决的,我也遇到这样的问题了。
发表于 2014-4-4 16:23:58 | 显示全部楼层
Do you have checked timing by the sta at Post-layout net list. The timing report doesn't any timing violation. If not, I though the scan path has a hold time violation. You must be fixed it.
GMT+8, 2025-12-30 05:12 , Processed in 0.014960 second(s), 6 queries , Gzip On, Redis On.
