查看: 11028|回复: 5
[求助] 关于CELL 在target_library 找不到的问题
发表于 2012-2-2 17:19:05 | 显示全部楼层 |阅读模式
各位好:
我在用DC 做综合时,在des.tcl中设置target_library ,并且定义了DC 时用的 set AHFS_BUF    “FJSCE2BUFXL1 FJSCE2BUFXQ1 。。。“
set_ahfs_options -optimize_buffer_trees true -constant_nets true -default_reference $AHFS_BUF
为什么在运行compile_ultra -no_autoungroup -congestion -spg -no_seq_output_inversion 时会出现
Warning: Could not find lib_cell 'FJSCE2BUFXL1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXN1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXP1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXQ1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXR1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXT1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXU1' specified as -default_reference, in target_library.
Warning: Could not find lib_cell 'FJSCE2BUFXV1' specified as -default_reference, in target_library.
Error: AHFS: Invalid buffer cell(s) specified for the -default_reference option. (PSYN-621)
这样的错误,但是FJSCE2BUFXL1等CELL 在target_library 里面是有的;请问有哪些情况会导致这个问题?
谢谢!
 楼主| 发表于 2012-2-2 17:39:44 | 显示全部楼层
回复 1# alicez719
补充一下:在运行
时会load target_library ,如下:Loading target library 'cs302sz_uc_scan4_s_m40_098v'
  Loading target library 'cs302sz_uc_dscan4_s_m40_098v'
  Loading target library 'cs302sn_uc_scan4_s_m40_098v'
  Loading target library 'cs302sn_uc_dscan4_s_m40_098v'
  Loading target library 'cs302sl_uc_scan4_s_m40_098v'
  Loading target library 'cs302sl_uc_dscan4_s_m40_098v'
  Loading target library 'cs302sz_uc_scan_s_m40_098v'
  Loading target library 'cs302sz_uc_nscan_s_m40_098v'
  Loading target library 'cs302sz_uc_eco_s_m40_098v'
  Loading target library 'cs302sz_uc_dscan_s_m40_098v'
  Loading target library 'cs302sn_uc_scan_s_m40_098v'
  Loading target library 'cs302sn_uc_nscan_s_m40_098v'
  Loading target library 'cs302sn_uc_eco_s_m40_098v'
  Loading target library 'cs302sn_uc_dscan_s_m40_098v'
  Loading target library 'cs302sl_uc_scan_s_m40_098v'
  Loading target library 'cs302sl_uc_nscan_s_m40_098v'
  Loading target library 'cs302sl_uc_eco_s_m40_098v'
  Loading target library 'cs302sl_uc_dscan_s_m40_098v‘
为什么没有包含我在des.tcl里定义的所有target_library;上面的这几个library确实不包括FJSCE2BUFXL1等CELL
请问这是什么问题 ?
谢谢!
发表于 2012-2-3 09:31:12 | 显示全部楼层
这是什么fab,什么库啊
发表于 2012-2-3 09:50:20 | 显示全部楼层
一看像fujisu的库,去库里看看BUF啥名字
 楼主| 发表于 2012-2-3 10:31:36 | 显示全部楼层
回复 4# reddamm
   就是我上面说的名字
发表于 2012-2-3 11:20:04 | 显示全部楼层
echo $target_library看看
GMT+8, 2025-11-18 05:37 , Processed in 0.018733 second(s), 5 queries , Gzip On, Redis On.
