查看: 8482|回复: 27
[原创] 2011.11 JSSC bandgap reference
发表于 2011-12-1 10:20:25 | 显示全部楼层 |阅读模式
Abstract:
A CMOS bandgap reference with an inaccuracy of ±0.15% (3 σ) from -40°C to 125°C is presented. In contrast to prior art, it requires only a single trim to achieve this level of precision. A detailed analysis of the various error sources is provided, and techniques to reduce them are discussed. The prototype bandgap reference draws 55 μA from a 1.8 V supply, and occupies 0.12 mm2 in a 0.16 μm CMOS process. Experimental results from two runs show that, with the use of chopping and higher-order curvature correction to remove non-PTAT errors, the residual error of a bandgap reference is mainly PTAT, and can be removed by a single room temperature trim.
abbr_af40d8195618d7f6eaabbeed1567224c.pdf
2.32 MB, 下载次数: 481 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-12-1 10:24:17 | 显示全部楼层
good good good
发表于 2011-12-1 13:27:01 | 显示全部楼层
我日,简介很吓人啊。太生猛了吧~~
发表于 2011-12-1 13:44:58 | 显示全部楼层
最猛的是这招,很赞的说!
发表于 2011-12-1 18:01:56 | 显示全部楼层
牛牛牛!!!
发表于 2011-12-2 00:33:11 | 显示全部楼层
确实够猛
发表于 2011-12-4 10:25:16 | 显示全部楼层
很威啊
发表于 2011-12-6 10:35:57 | 显示全部楼层
谢谢分享。
发表于 2011-12-6 12:03:02 | 显示全部楼层
Thanks for your share,
发表于 2011-12-6 14:06:43 | 显示全部楼层
围观膜拜贴~~
GMT+8, 2025-12-21 00:37 , Processed in 0.026879 second(s), 6 queries , Gzip On, Redis On.
