查看: 1877|回复: 0
[资料] virtex-5 family overview
发表于 2011-10-26 14:48:25 | 显示全部楼层 |阅读模式
The Virtex®-5 family provides the newest most powerful features in the FPGA market. Using the second generation ASMBL™ (Advanced
Silicon Modular Block) column-based architecture, the Virtex-5 family contains five distinct platforms (sub-families), the most choice
offered by any FPGA family. Each platform contains a different ratio of features to address the needs of a wide variety of advanced logic
designs. In addition to the most advanced, high-performance logic fabric, Virtex-5 FPGAs contain many hard-IP system level blocks,
including powerful 36-Kbit block RAM/FIFOs, second generation 25 x 18 DSP slices, SelectIO™ technology with built-in digitallycontrolled
impedance, ChipSync™ source-synchronous interface blocks, system monitor functionality, enhanced clock management tiles
with integrated DCM (Digital Clock Managers) and phase-locked-loop (PLL) clock generators, and advanced configuration options.
Additional platform dependant features include power-optimized high-speed serial transceiver blocks for enhanced serial connectivity,
PCI Express® compliant integrated Endpoint blocks, tri-mode Ethernet MACs (Media Access Controllers), and high-performance
PowerPC® 440 microprocessor embedded blocks. These features allow advanced logic designers to build the highest levels of
performance and functionality into their FPGA-based systems. Built on a 65-nm state-of-the-art copper process technology, Virtex-5
FPGAs are a programmable alternative to custom ASIC technology. Most advanced system designs require the programmable strength
of FPGAs. Virtex-5 FPGAs offer the best solution for addressing the needs of high-performance logic designers, high-performance DSP
designers, and high-performance embedded systems designers with unprecedented logic, DSP, hard/soft microprocessor, and
connectivity capabilities. The Virtex-5 LXT, SXT, TXT, and FXT platforms include advanced high-speed serial connectivity and
link/transaction layer capability.
virtex-5 family overview.pdf (313.75 KB , 下载次数: 8 )
GMT+8, 2025-12-23 00:49 , Processed in 0.014973 second(s), 5 queries , Gzip On, Redis On.
