查看: 4146|回复: 2
[原创] ICC: Merging FILL View Information Into the CEL View
发表于 2011-9-21 14:21:44 | 显示全部楼层 |阅读模式
In order to edit the FILL view. You can generate metal fill information from the FILL view and use this to insert metal fill in the CEL view. (Note that this can take a long time.)
To merge the FILL view into the CEL view,
1.        Open the FILL view.
icc_shell> open_mw_cel $design.FIL
2.        Save the metal fill information.
icc_shell> write_route -output_metal_fill  -output  metal_fill.tcl
3.        Close the FILL view.
icc_shell> close_mw_cel $design.FIL
4.        Open the CEL view.
icc_shell> open_mw_cel $design.CEL
5.        Source the metal fill information.
icc_shell> source -echo metal_fill.tcl
6.        Save the CEL view.
icc_shell> save_mw_cel -as design_FIL
7.        Remove the FILL view.
The FILL view is no longer required, because the metal fill data is now in the CEL view.
发表于 2011-9-26 10:14:46 | 显示全部楼层
Thanks for sharing
发表于 2014-2-14 19:32:21 | 显示全部楼层
谢谢分享。
另,请问如果用calibre fill metal的话,生成的gds能否转成fill view?
GMT+8, 2025-9-15 03:21 , Processed in 0.014749 second(s), 3 queries , Gzip On, Redis On.
