查看: 14334|回复: 21
[求助] ams仿真,ic5141usr3+ius8.2+centos5.6,已经解决了!
发表于 2011-9-2 16:51:38 | 显示全部楼层 |阅读模式
Compilation successful.
ncelab: 08.20-p001: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
ncelab: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncelab 08.20-p001
  HOSTNAME: sim203
  OPERATING SYSTEM: Linux 2.6.18-238.el5xen #1 SMP Thu Jan 13 16:41:45 EST 2011 x86_64
  MESSAGE: Failed to open Spectre Simulation Image Generation library with error: /opt/ic5141usr3/tools/lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/libstdc++.so.6)
ncelab: Memory Usage - 18.7M program + 14.3M data = 33.0M total
ncelab: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.2s, 1.8% cpu)
Failed to elaborate ("temp" "temp_ams1" "config").
Goole了一下,也有类似问题,但是没有找到解决办法,大家帮忙!!!
Note:我安装的是Base_IUS08.20.001_lnx86,patch过了!没有提示feature missing,但是有这个问题!
搞定了
之前只安装base,有没有patch都有问题!
上午重新安装base,然后update,仿真,没有上述error,只是lic checkout fail,然后patch,ok了!
发表于 2011-9-2 18:50:41 | 显示全部楼层
you cannot install IC5141 USR3 on CentOS5.6..
 楼主| 发表于 2011-9-5 08:52:56 | 显示全部楼层
ic5141usr3 在centos5.6 能正常仿真模拟电路~
 楼主| 发表于 2011-9-5 13:26:29 | 显示全部楼层
搞定了
发表于 2011-12-16 15:08:39 | 显示全部楼层
发表于 2012-2-16 20:39:32 | 显示全部楼层
请问楼主,你用ams做混合仿真的时候,是怎么显示电路中电流值的,我目前碰到这个问题了
发表于 2012-3-7 20:42:13 | 显示全部楼层
楼主高手啊~~~~~
发表于 2012-4-12 11:51:15 | 显示全部楼层
LZ  我怕IC614+ius920已经成功安装,但是跑AMS设置加载connectlib时···cell只有一个readme,
view那边什么都没有,什么问题呢?????
发表于 2012-5-26 12:10:01 | 显示全部楼层
    请教如何进行update呢,我也碰到类似的问题!
发表于 2012-10-24 17:25:59 | 显示全部楼层
没积分了,赚点。。。。
GMT+8, 2025-12-23 15:48 , Processed in 0.024682 second(s), 5 queries , Gzip On, Redis On.
