在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
返回列表 发新帖
楼主: henry_wangjj
[求助] overlap clock如何做CTS
 楼主| 发表于 2011-8-24 17:14:59 | 显示全部楼层
回复 7# 陈涛
    I've done CTS using the method given:
clk1, and clk2 have no sinks, and the clock tree is built rignt from mux/Y(in our design, clk1 comes from PAD, clk2 comes from and OSC), I do think the result is as expected, is this right?
besides, a Warning(there are multiple arcs between the input and output of the MUX)is issued since case_analysis on mux/S is removed, is this warning to be ignored?
thanks in advance.
 楼主| 发表于 2011-8-24 17:23:37 | 显示全部楼层
and one more question,
during synthesis, I think there's no need to do incremental mapping for clk1(or clk2).
Using clk1(or clk2) as the clock source with the proper set_case_analysis is fine since clk1&clk2 are the same to synthesis
yeah?
发表于 2014-5-22 23:53:21 | 显示全部楼层
mark下,没明白
发表于 2015-1-11 15:21:37 | 显示全部楼层
回复 9# tianxiong_14
   那么可以先长mux Y端后的,然后设置成dont touch 应该也是可以的。我不太理解你说的3个clock设置成一样 是什么意思,是creat clock的定义吗?dc阶段还是icc啊
发表于 2021-2-19 09:44:54 | 显示全部楼层
请教下, clock1 和clock2 没有必要做balance ,为何还要放在一个group中啊
GMT+8, 2025-6-28 20:15 , Processed in 0.016405 second(s), 7 queries , Gzip On, MemCached On.
