查看: 5610|回复: 2
[求助] Xilinx问题求助
发表于 2011-8-22 21:44:40 | 显示全部楼层 |阅读模式
'1': Programming terminated. DONE did not go high.INFO:iMPACT:2217 - Error shows in the status register, CRC Error bit is NOT 0.
INFO:iMPACT:2218 - Error shows in the status register, release done bit is NOT 1.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 1011 0000 0011 0000 0000 0011 1100 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
PROGRESS_END - End Operation.
Elapsed time =     10 sec.
求助啊。出现这个问题引起的下载不进去的。但怎么解决啊。
发表于 2011-8-23 10:51:47 | 显示全部楼层
貌似你的JTAG硬件连接有问题。
 楼主| 发表于 2011-8-23 22:59:08 | 显示全部楼层
回复 2# HXW718059156
    请那该如何解决呢?知道是什么原因引起的嘛?以前还很好的。谢谢!
GMT+8, 2025-12-18 08:51 , Processed in 0.020456 second(s), 5 queries , Gzip On, Redis On.
