查看: 3472|回复: 9
[求助] how to assign pads to a sub-block layout.
发表于 2011-7-12 10:15:50 | 显示全部楼层 |阅读模式
Dear all, here comes a trouble when I am doing rectilinear floor planning using Astro.
I need to assign both PADs and pins to a T-shaped rectilinear floorplan, which is a sub-block of a design, but the PADs are not placed properly when I initialized floorplan, Could anyone give me some advice ?
or some instruction on the full-chip layout design?
 楼主| 发表于 2011-7-13 17:34:16 | 显示全部楼层
Could anyone give me some help ?or anything about the hierarchical floorplan or the layout of IP with PADs?
Thanks in advance!
发表于 2011-7-13 22:46:59 | 显示全部楼层
ICC中-side选项吧
 楼主| 发表于 2011-7-16 07:26:23 | 显示全部楼层
回复 3# 1359784773
    Thank you very much, we planned to implement the layout using Astro at this stage since we are not very familiar with ICC.
And, I have communicated with an engineer of synopsys, they suggest to place the PADs manually, treating the PAD as normal macros.
发表于 2011-7-16 23:45:12 | 显示全部楼层
very easy, place the PADS manually,
you are in shanghai ? we can help you on site ,
 楼主| 发表于 2011-7-21 01:06:35 | 显示全部楼层
回复 5# icfbicfb
Thank icfbicfb very much, as what you have said, the PAD could  be modified manually.
however,  when I try to assign the Pins by loading the TDF files, Astro give the Error info as shown below:
INFO: point set is clockwise
INFO: top boundary has 8 sides
INFO: 0 IO pins considered in design
INFO: there is no valid pins to work on
ERROR: rectilinear pin initial placement failed.
all of the Pins couldn't be placed, for example, clk_osc, which comes from the analog block, serves as an input port in the top module of the digital block, when I loaded the netlist, Astro gives the following Warnings:
WARNING : boundary port clk_osc has no pin
  treat net clk_osc as pseudo net and mark it dont_touch
Any help?
thanks in advance!
发表于 2011-7-21 07:59:36 | 显示全部楼层
as for rectilinear floorplan ,  please use axgRectiPlanner,
or  create boundary yourself,  like geAddRectilinearBoundary ,
axgRectiPlanner
setFormField "Rectilinear Floor Planning" "Mode" "Enter Boundary"
 楼主| 发表于 2011-7-21 08:10:50 | 显示全部楼层
回复 7# icfbicfb
    Thanks, info. given above is right from axgRectiPlanner.
I remember in ICC, floating Pins should set some constraints, and is this needed in Astro?
发表于 2011-7-22 20:40:04 | 显示全部楼层
yes , in  tdf file , can set som constraints ,
发表于 2017-3-18 00:35:15 | 显示全部楼层
Thanks
GMT+8, 2025-10-19 23:32 , Processed in 0.020487 second(s), 5 queries , Gzip On, Redis On.
