查看: 16737|回复: 4
[求助] DC里的set_critical_range什么意思
发表于 2011-3-17 16:39:40 | 显示全部楼层 |阅读模式
DC脚本里有这样一行:
set_critical_range 2 [current_design]
请问,这句是什么意思呀,set_critical_range 后边数字2代表什么?
O(∩_∩)O谢谢!
 楼主| 发表于 2011-3-17 21:27:39 | 显示全部楼层
Critical range specifies a margin of delay for path groups in optimization.   This  must be a positive float number or 0.0.  A critical rangeof 0.0 means that only the most critical paths (the ones with the worst violation)  are  optimized.   If  you specify a nonzero critical range,
near-critical paths within that amount of the worst path will  also  be optimized, if possible.
明白了,下午没好好看,就没有看懂……
发表于 2011-6-30 14:19:16 | 显示全部楼层
我也明白了,谢了
发表于 2013-11-22 12:39:12 | 显示全部楼层
GMT+8, 2025-12-22 02:54 , Processed in 0.020194 second(s), 5 queries , Gzip On, Redis On.
