查看: 11277|回复: 24
[求助] EEPROM存储器是数模混合芯片吗?
发表于 2011-3-14 17:09:41 | 显示全部楼层 |阅读模式
EEPROM存储器主要包括升压电路,灵敏放大器还有外围控制逻辑电路、译码电路、地址/数据锁器。
想问下,外围控制逻辑电路、译码电路、地址/数据锁器是用数字电路实现的吗?
还有EEPROM和MTP存储器有什么区别?
发表于 2011-3-14 21:27:41 | 显示全部楼层
EEPROM circuit design: Fully customized circuit design.
Answer: No!
EEPROM: One of the MTP memory types
MTP: Multiple-time Programmable
发表于 2011-3-14 21:51:55 | 显示全部楼层
LZ在做UHF RFID?
发表于 2011-3-14 23:00:31 | 显示全部楼层
Memory Chip
 楼主| 发表于 2011-3-15 09:29:27 | 显示全部楼层
回复 3# tanguaner
嗯  可以多交流下
 楼主| 发表于 2011-3-15 09:39:37 | 显示全部楼层
    哦。那控制逻辑电路和译码电路不能用数字电路设计的方法,先用Verilog实现,做成数字的版图,最后把原理图抽出来拼版吗?
发表于 2011-3-15 13:33:08 | 显示全部楼层
The address and command decoders are too simple in EEPROM,
and the row and column decoders are too regular, that IC (silicon) design does not benefit much from logic design flow.
After the logic synthesis, it would be automatic placement of cells and auto-route.
The area utilization efficiency in general (of such design flow) is relatively low, compared to fully customized layout and manual route.  If the cells are too regular, silicon design does not benefit from APR (Auto Place-&-Route) flow.
EEPROM, like other memory ICs, does not use the same amount of metal layers as logic ICs usually do.
This is another reason why EEPROM design does not benefit from logic synthesis then APR flow.
Please be aware that I am not saying you CAN'T use logic design flow to implement the aforementioned parts in the EEPROM.  I simply say there's not much benefit doing so.
Therefore people wouldn't do things that way.
The short answer is EEPROM IC design uses fully customized circuit design flow.
 楼主| 发表于 2011-3-16 09:34:12 | 显示全部楼层
and the row and column decoders are too ...
fhchen2002 发表于 2011-3-15 13:33
    嗯,听您这么一说,受益匪浅,非常感谢您的回答!
发表于 2013-3-12 17:54:09 | 显示全部楼层
eeeeeeeeeeeeeeeeeeeeeetttop
发表于 2014-4-21 15:44:58 | 显示全部楼层
学习MTP&EEPROM
GMT+8, 2025-12-9 04:14 , Processed in 0.026081 second(s), 7 queries , Gzip On, Redis On.
