查看: 44838|回复: 134
[其它] Xilinx ISE 13.1 LicGen (License Generator)
发表于 2011-3-4 16:29:40 | 显示全部楼层 |阅读模式
Xilinx ISE 13.1 License Generator.
LicGen support Xilinx ISE Design Suite 13.1 version.
licgen_ise_13.1.rar
285.91 KB, 下载次数: 2106 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-3-4 16:50:18 | 显示全部楼层
after i run exe file,it's as all at here,it's diffirent version 12
# ----- REMOVE LINES ABOVE HERE -------------------------- #
# This license is valid from the moment it was generated.
# This is license NODELOCKED to HOSTID=xxxxxxxxxxxx;
# there is no need to run lmgrd for this license.
# This license is valid for very long time... :-)
INCREMENT System_Edition xilinxd 2011.03 1-jan-2020 uncounted \
        618D9A20B85D HOSTID=xxxxxxxxxxxx ISSUER="Young Xilinx user" \
        START=1-Apr-2010 TS_OK
# The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE System_Edition xilinxd 2011.03 AAF075B64F91 \
        COMPONENTS="AccelDSP ChipscopePro_SIOTK ChipscopePro ISIM \
        SysGen ISE sdk xps PlanAhead" OPTIONS=SUITE
# ----- REMOVE LINES BELOW HERE --------------------------
发表于 2011-3-4 16:55:18 | 显示全部楼层
还行,呵呵
 楼主| 发表于 2011-3-4 16:55:44 | 显示全部楼层
It works for ISE 13.1.
发表于 2011-3-4 21:36:29 | 显示全部楼层
不停的更新
 楼主| 发表于 2011-3-4 21:39:28 | 显示全部楼层
有人可以检查吗?
发表于 2011-3-5 04:41:25 | 显示全部楼层
3QQQQQQQQQ
发表于 2011-3-5 08:44:19 | 显示全部楼层
Thanks
发表于 2011-3-5 08:48:02 | 显示全部楼层
thanks!!!
发表于 2011-3-5 11:12:26 | 显示全部楼层
非常感谢。。
GMT+8, 2025-9-13 14:18 , Processed in 0.028808 second(s), 7 queries , Gzip On, Redis On.
