查看: 6393|回复: 16
[求助] 请教:HSPICE 后仿真出错!
发表于 2011-1-27 19:31:51 | 显示全部楼层 |阅读模式
请问一下,
用HSPICE作后仿真时,
出现报错,
就是
说没有从节点到地,没有DC同路,
no dc path from node net11 to groud
但是电路中没有悬空的电容和电阻,
请问高手,这是怎么回事?
怎么解决呢?
 楼主| 发表于 2011-1-27 19:35:39 | 显示全部楼层
请高手不吝指教,
不胜感激!
发表于 2011-1-27 22:08:47 | 显示全部楼层
找到节点,
手动加一大电阻连接地。..
R00001 net11 0 1e12
回复 支持 0 反对 1
发表于 2011-1-28 01:49:57 | 显示全部楼层
Spice requires that every node in a circuit have a DC path to ground (ie node "0"). Be careful when, for example, connecting two capacitors at a node. Such a node between caps would have no DC path to ground and would cause Spice to reject the input file. To fix this connect a huge (ie 1 G-ohm or so resistor from the node in question to ground. This will hardly change the circuit but will provide that vital DC path to ground.
 楼主| 发表于 2011-1-28 08:46:28 | 显示全部楼层
 楼主| 发表于 2011-1-28 08:47:31 | 显示全部楼层
Spice requires that every node in a circuit have a DC path to ground (ie node "0"). Be careful when, ...
nicolast0604 发表于 2011-1-28 01:49
thanks a lot
I will have a try
 楼主| 发表于 2011-1-28 10:43:24 | 显示全部楼层
找到节点,
手动加一大电阻连接地。..
R00001 net11 0 1e12
Areky 发表于 2011-1-27 22:08
但是没有dc通路到地的节点太多了,
至少有百个以上,
一个一个加肯定很费事的,
请问还有其他办法吗?
 楼主| 发表于 2011-1-28 10:55:35 | 显示全部楼层
除此以外还有别的办法吗
可不可以修改HSPICE的仿真精度?
 楼主| 发表于 2011-1-28 12:47:47 | 显示全部楼层
万分火急!
求高人的帮助!
发表于 2011-1-29 01:23:47 | 显示全部楼层
不知道。。。
GMT+8, 2025-10-29 04:20 , Processed in 0.022353 second(s), 6 queries , Gzip On, Redis On.
