查看: 4792|回复: 0
[求助] ERROR:Pack:1107 - Unable to combine the following symbols into a single IOB
发表于 2011-1-7 10:50:51 | 显示全部楼层 |阅读模式
ERRORack:1107 - Unable to combine the following symbols into a single IOB
   component:
    BUF symbol "lcd_data_7_IOBUF/IBUF" (Output Signal = N2091)
    TBUF symbol "lcd_data_7_IOBUF/OBUFT" (Control Signal = lcd_data_not0001_inv)
    PAD symbol "lcd_data<7>" (Pad Signal = lcd_data<7>)
   Each of the following constraints specifies an illegal physical site for a
   component of type IOB:
    Symbol "lcd_data<7>" (LOC=P97)
   Please correct the constraints accordingly.
MAP过程中报以上错误,好像可以通过修改工程的属性可以解决此问题,但是不知道具体修改哪些参数,请高手们指点。
板子已经做好,所以改管脚是很麻烦的。
lcd_data的数据类型是inout
LOC=P97 管脚的类型是IO/VREF
GMT+8, 2025-12-6 06:03 , Processed in 0.013813 second(s), 5 queries , Gzip On, Redis On.
