查看: 8177|回复: 25
[资料] Strength-Reduced Parallel Chien Search Architecture for Strong BCH Codes
发表于 2011-1-6 22:15:25 | 显示全部楼层 |阅读模式
Abstract—The Chien search process is the most complex block
in the decoding of Bose–Chaudhuri–Hochquenghem (BCH) codes.
Since the BCH codes conduct the bit-by-bit error correction, they
often need a parallel implementation for high throughput applications.
The parallel implementation obviously needs much increased
hardware. In this paper, we propose a strength reduced architecture
for the parallel Chien search process. The proposed method
transforms the expensive modulo- 􀀀  multiplications into shift
operations, by which not only the hardware for multiplications but
also that for additions are much reduced. One example shows that
the hardware complexity is reduced by 90% in the implementation
of binary BCH (8191, 7684, 39) code with the parallel factor of 64.
Consequently, it is possible to achieve a speedup of 64 with only 13
times of the hardware complexity when compared with the serial
processing.
Strength-Reduced Parallel Chien Search.pdf (247.36 KB , 下载次数: 139 )
发表于 2011-1-7 09:23:23 | 显示全部楼层
回复 1# shaweikang1984
Thank you
发表于 2011-1-7 09:24:50 | 显示全部楼层
下来看看,谢谢。
发表于 2011-1-7 10:45:42 | 显示全部楼层
呵呵,谢谢楼主
发表于 2011-1-8 14:05:22 | 显示全部楼层
多谢楼主分享。
发表于 2011-1-8 14:20:42 | 显示全部楼层
谢谢啊
发表于 2011-1-8 23:05:21 | 显示全部楼层
Thanks!!!!
发表于 2011-1-9 17:39:02 | 显示全部楼层
    thanks
发表于 2011-1-11 09:28:44 | 显示全部楼层
great article
发表于 2011-1-12 11:40:12 | 显示全部楼层
kankan
GMT+8, 2025-12-11 08:27 , Processed in 0.600625 second(s), 6 queries , Gzip On, Redis On.
