查看: 3661|回复: 7
[求助] 正弦信号输入ADC每一位输出数字码怎么确定
发表于 2010-12-26 15:13:48 | 显示全部楼层 |阅读模式
如果给ADC输入加一个正弦波,我想知道ADC输出每一位的数字码是怎样变化的,这个可以吗?有没有关于ADC输出各位的时域的表达式啊?
发表于 2010-12-26 21:53:45 | 显示全部楼层
Yes, of course.
Is MATLAB script OK for you?
 楼主| 发表于 2010-12-26 22:50:37 | 显示全部楼层
回复 2# fhchen2002
    我没有用MATLAB啊,就是想知道输出各位的数字码是怎样变化的,有没有一些时域抑或频域的表达式
 楼主| 发表于 2010-12-27 11:45:33 | 显示全部楼层
回复 4# waveguides
    我想分析DAC电流源随机误差对于SFDR的影响,于是想知道ADC输入正弦信号输出各位的变化。
发表于 2010-12-27 13:07:56 | 显示全部楼层
回复 3# favourite626
The digital outputs are function of the following paramters:
  • Input frequency
  • Amplitude of input sinasoidal
  • DC offset of sinasoidal
  • Quantization level
  • Sampling frequency
A close-form lookup table is not possible.
For example,
Input frequency = 2.19532 MHz
Sampling frequency = 50 MHz
Sampling frequency is not an integer multiple of the input frequency, so the output digital code will not repeat in short period of time.
Using a spreadsheet or a script from a high-level language with a control equation to generate the 0/1 outputs is usually the reasonable approach.
发表于 2010-12-27 13:28:01 | 显示全部楼层
ahdlLib里面有理想ADC可以用来仿真
发表于 2010-12-27 13:28:57 | 显示全部楼层
    Normally such an analysis is conducted in MATLAB script.
 楼主| 发表于 2010-12-27 23:03:18 | 显示全部楼层
回复 8# fhchen2002
    恩,谢谢啦,我再研究研究
GMT+8, 2025-12-25 05:59 , Processed in 0.679340 second(s), 6 queries , Gzip On, Redis On.
