查看: 4736|回复: 4
[求助] 使用smic自带的CG cell后的时序分析问题
发表于 2010-11-13 14:41:59 | 显示全部楼层 |阅读模式
smic库中自带的门控时钟单元是一个latch+and复合的单元,
综合后加入门控选项,DC自动添加该单元,结果导致时序分析时,终点在latch上,由于时钟取反,导致时序不满足
而如果自己例化latch 和 and做门控,时序分析时终点在and上,时序就可以满足
请问大侠如何解决该问题,是否只能自己例化,而不能使用smic自带的单元
发表于 2010-11-13 16:33:16 | 显示全部楼层
clock gating cell  TLATNTSCA,  check setup 用的是半个时钟周期, 感觉应该时用一个时钟周期.
为什么pt用下降沿,而不是上升沿去check setup ????
Startpoint: u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/cycle_reg_3_0
               (rising edge-triggered flip-flop clocked by clkcpu)
  Endpoint: u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/clk_gate_memaddr_s_reg/latch
               (rising clock gating-check end-point clocked by clkcpu')
  Path Group: **clock_gating_default**
  Path Type: max
  Point                                                   Incr       Path
  clock clkcpu (rise edge)                               0.000      0.000
  clock network delay (propagated)                       1.895      1.895
  u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/cycle_reg_3_0/CK (SDFFQX4)
                                                         0.000      1.895 r
  u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/cycle_reg_3_0/Q (SDFFQX4)
                                                         0.373 &    2.268 r
  u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/clk_gate_memaddr_s_reg/latch/E (TLATNTSCAX8)
                                                         4.267 &    6.536 f
  data arrival time                                                 6.536
  clock clkcpu' (rise edge)                              4.000      4.000
  clock network delay (propagated)                       1.134      5.134
  clock reconvergence pessimism                          0.000      5.134
  u_ts_r8051xc/U_R8051XC_U_R8051XC_CPU/clk_gate_memaddr_s_reg/latch/CKcheckpin1 (TLATNTSCAX8)
        5.134 r
  clock gating setup time                               -0.223      4.911
  data required time                                                4.911
  data arrival time                                                -6.536
  slack (VIOLATED)                                                 -1.625
发表于 2010-11-13 16:35:42 | 显示全部楼层
楼上是时序报告
发表于 2010-11-13 19:00:39 | 显示全部楼层
学习了!!
发表于 2010-11-13 21:23:02 | 显示全部楼层
tks for sharing
GMT+8, 2025-12-26 20:05 , Processed in 0.019636 second(s), 5 queries , Gzip On, Redis On.
