发表于 2010-11-12 16:34:20
显示全部楼层
Yes, we could certainly use common-source at the output stage.
I just wondered why did you use a hi ...
shiunger 发表于 2010-11-12 15:04
Unfortunately, you are wrong.
since it is a closed loop, the output impedance is low at the output, at least at low frequency. So, it can work as a voltage source to drive a low impedance. Thanks!
