小弟用connect_tie_cells 加入tie-off cell时只能加入一部分tie cell ,还是有一些cell的 tie-off pin 不能连接到tie cell上面去。
输出的网表里面会有assign :
assign GND = 1'b0;
ADD_000_111_51 add0_3 (.x ( m3n1 ) , .y ( GND ) , .z ( m4n0 ) , .s ( s0_3 ) ,
.c ( c0_3 ) ) ;
我用icc0809sp5和icc0906sp3都试过了,解决不了。
按照synopsys的流程也不行。
在solvnet看到的解释是:
Starting with version D-2010.03-SP3, the connect_tie_cells command is enhanced to
support additional connection modes for hierarchical ports. In previous releases, only tie-off
net connections to port instances at higher levels of the design hierarchy were supported.
IC Compiler version D-2010.03-SP3 extends support to tie-off connections originating from
lower levels of the hierarchy. Feedthrough tie-off connections are also supported in version
D-2010.03-SP3。
既然这样,那么201003之前的版本都不能解决tie 的问题, 请问大家是怎么解决的??
难道要在代码里面将各层tie-off的pin全部接到设计的顶层,然后再接到1‘b0和1’b1
。然而即使这样,综合的时候还是有可能在low level产生额外的tie-off pin。 |
