查看: 7830|回复: 26
[资料] Layout Consideration to Prevent electrical overstress failure (High-Voltage)
发表于 2014-3-18 22:00:14 | 显示全部楼层 |阅读模式
Layout Consideration and Circuit Solution to Prevent
EOS Failure Induced by LatchupTest in a High-Voltage Integrated Circuits
Abstract—This paper presented a practical industry case of
electrical overstress (EOS) failure induced by the latchup test
in high-voltage integrated circuits (ICs). By using proper layout
modification and additional circuit, the unexpected EOS failure,
which is caused by negative-current-triggered latchup test, can
be successfully solved. The new design with proposed solutions
has been verified in the 0.6-μm 40-V Bipolar CMOS DMOS
(BCD) process to pass the test for at least 500-mA trigger current,
which shows high negative-current-latch-up immunity without
overstressdamage,comparedwiththeprotectionofonlytheguard
ring.Suchsolutionscanbeadoptedtoimplementhigh-voltage-ap-
plicableICproducttomeettheindustryrequirementforthemass
productionof ICmanufactures and applications.
IndexTerms—Electricaloverstress(EOS),high-voltageCMOS,
latchup,regulator.
发表于 2014-3-24 09:29:38 | 显示全部楼层
Where's the attached?
发表于 2014-3-24 10:18:03 | 显示全部楼层
Layout Consideration to Prevent electrical overstress failure.pdf (1.04 MB , 下载次数: 292 )
发表于 2014-4-25 10:08:49 | 显示全部楼层
发表于 2014-4-25 19:44:04 | 显示全部楼层
发表于 2014-7-23 14:24:07 | 显示全部楼层
谢谢楼主
发表于 2014-9-14 15:25:33 | 显示全部楼层
回复 3# xiaowanzi88
版主好人
发表于 2014-9-14 18:59:03 | 显示全部楼层
hao dong xi!!!
发表于 2014-9-16 12:35:37 | 显示全部楼层
谢谢分享
发表于 2015-3-14 00:15:27 | 显示全部楼层
a good one. Thanks for sharing
GMT+8, 2025-11-22 08:57 , Processed in 0.025661 second(s), 6 queries , Gzip On, Redis On.
