查看: 6690|回复: 18
[资料] A NEW 4-PHASE CHARGE PUMP WITHOUT BODY EFFECTS FOR LOW SUPPLY VOLTAGES
发表于 2010-8-17 06:45:35 | 显示全部楼层 |阅读模式
A NEW 4-PHASE CHARGE PUMP WITHOUT BODY EFFECTS FOR LOW SUPPLY VOLTAGES A NEW 4-PHASE CHARGE PUMP WITHOUT BODY EFFECTS FOR LOW SUPPLY VOLTAGES.pdf (91.89 KB , 下载次数: 162 )
For your reference
发表于 2010-8-17 09:07:20 | 显示全部楼层
DDDDDD
发表于 2010-8-19 22:03:20 | 显示全部楼层
好东西,谢了
发表于 2010-8-29 21:26:31 | 显示全部楼层
very ths
发表于 2011-1-12 10:34:06 | 显示全部楼层
thanks a lot
发表于 2011-1-12 15:53:27 | 显示全部楼层
ddddddddddddddddddddd
发表于 2011-1-12 18:05:44 | 显示全部楼层
Authors: HongChin Lin, JainHao Lu, Yen-Tai Lin
This paper appears in 2002 IEEE Asia-Pacific Conference
Abstract:
A new four-phase charge pumping circuit for low supply voltages using 0.6um triple-well CMOS technology to generate high negative boosted voltage is presented.  With the new substrate connected technique, the influence of threshold voltagte (-0.94 V) is minimized and the body effect is almost eliminated.  A five-stage charge pump can effeciently pump lower than -7V at supply voltage of 1.8V with 100 uA loading current.
Yen-Tai Lin is with eMemory Technology 力旺科技
HongChin Lin and JainHao Lu are with Chung-Hsing Univ. 中興大學 TaiChung 台中, Taiwan
发表于 2011-1-12 20:39:15 | 显示全部楼层
Thanks for your sharing!
发表于 2011-1-30 10:21:09 | 显示全部楼层
thanks!!!!!
发表于 2011-2-25 16:05:03 | 显示全部楼层
回复 4# bjsuperpower
GMT+8, 2025-12-21 14:14 , Processed in 0.025165 second(s), 9 queries , Gzip On, Redis On.
