查看: 1889|回复: 0
[求助] question about buffer
发表于 2010-5-10 10:45:23 | 显示全部楼层 |阅读模式
The positive terminal of buffer is connected to a 4MHz signal and output is expected to follow its averaged DC value, is it necessary to make the bandwidth of buffer larger than 40MHz to make the buffer has about 20dB gain  when the freq = 4MHz?
GMT+8, 2025-12-20 10:43 , Processed in 0.014766 second(s), 6 queries , Gzip On, Redis On.
