查看: 3688|回复: 2
[求助] Question about a simple VCO phase noise model
发表于 2010-4-6 15:20:34 | 显示全部楼层 |阅读模式
I see a phd paper form fudan university, the author give a simple VCO phase noise mode like following:
                   Svco,n=A(f1/f)^3 + B(f2/f)^2 + C;
A is phase noise at offset f1(1/f^3 region), unit dBc/Hz;
B is phase noise at offset f2(1/f^2 region), unit dBc/Hz;
C is the VCO noise floor, unit dBc/Hz;
who can explain why the vco phase noise model can like this? And the f1 and f2 no need special value in the seperate region?
发表于 2010-4-6 15:47:56 | 显示全部楼层
Dear 123:
A,B,C is fitting parameter by measurment.
its a simple piece-wise-linear model.
u can write A*f1^3=A1,B*f2^2=B2
then get an easier equation...
发表于 2016-3-17 23:38:18 | 显示全部楼层
who know it???
GMT+8, 2025-12-26 00:58 , Processed in 0.018662 second(s), 6 queries , Gzip On, Redis On.
