查看: 3354|回复: 1
[求助] 大家看看这是几倍频?
发表于 2010-1-1 21:32:08 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity twice is
port (clk,rst:in std_logic;
clk_outut std_logic);
end twice;
architecture rtl of twice is
signal clk_temp:std_logic;
signal d_out:std_logic;
signal d_outn:std_logic;
begin
process(clk_temp,rst)
begin
if(rst='1') then
d_out<='0';
else
if(clk_temp'event and clk_temp='1') then
d_out<=d_outn;
end if;
end if;
end process;
clk_temp<=clk xor d_out;
clk_out<=clk_temp;
d_outn<=not d_out;
end rtl;
 楼主| 发表于 2010-1-2 19:42:07 | 显示全部楼层
拜托了!
GMT+8, 2025-12-21 19:30 , Processed in 0.014737 second(s), 3 queries , Gzip On, Redis On.
