做Preroute>Macros/Pads...时报如下warning,(有19条)
WARNING: Failed to make a connection for the following pin: ((899.810, 889.225) (901.810, 1122.165)) (Net: VSS)(wire on layer: METAL2 [36])
((339.555, 1399.535) (460.875, 1401.535)) (Net: VSS)(wire on layer: METAL3 [42])
((336.955, 1165.995) (463.475, 1167.995)) (Net: VDD)(wire on layer: METAL3 [42])
我使用了ram,查看ram的lef文件,发现VSS,VDD定义在METAL2,METAL3,这个warning和ram的VSS,VDD层有关吗?我尝试过用METAL2,METAL3布线,和在MACRO外加power ring同样有warning。很疑惑,不知道问题出在那里。请大家指点一下。 |
