查看: 2444|回复: 1
DSP System Engineer (Shenzhen)
发表于 2009-9-5 12:16:35 | 显示全部楼层 |阅读模式
Position: DSP System Engineer (Shenzhen)
Job Description:
1. An excellent opportunity to work with State-of-the-Art Multi-core ARM/DSP solutions. We are looking a number DSP firmware Engineers responsible for DSP coding, debugging and system integration.
2. Provide technical support to customers in Asia Pacific, primarily in China.
3. Work closely with field application engineers and customers, involve in product design, development, debugging and testing.
Experience Required:
1. BS/MS Electrical Engineering or related fields with more than 3+ years experience with solid background in Digital Signal Processing and Digital Communications Theory. Candidates with 7+ year of experience can be considered for the Senior DSP System Engineers.
2. Must have extensive experience in DSP implementation and optimization in C, C++ and assembly language. Signal processing and communication theory are essential.
3. Must have extensive fixed point DSP coding experience with excellent real-time debug skills is crucial.
4. Must possess good software debugging skills – experience in both the lab and in the field are essential.
5. Should be familiar with one of the followings areas: voice codecs (G.7xx, EVRC, AMR etc), video codecs (H.263, H.264 ,MPEG4 etc), audio codecs (MP3, AAC etc),voice band modem (V.90/V.92, V.34 etc), Modem over IP and T38 Fax over IP.
6. CEVA DSP 1620/1641 knowledge/experience is a PLUS.
7. Must have excellent communication skill and proficiency in written and oral English.
Contact: jingli888ca@yahoo.com
时间:从2010/05开始,至2010/11止,或面议。
 楼主| 发表于 2010-3-7 01:34:10 | 显示全部楼层
Ding!
GMT+8, 2025-10-4 11:06 , Processed in 0.618087 second(s), 5 queries , Gzip On, Redis On.
