查看: 2275|回复: 4
高手请进:LDV51在linux环境下安装的问题
发表于 2009-8-28 14:07:07 | 显示全部楼层 |阅读模式
LDV51在linux环境下安装时,显示下面的问题,哪位高手知道怎么解决?万分感激!我将奉上100信元!
[root@localhost CDROM1]# ./SETUP.SH
Copyright 1985-1999 by Cadence Design Systems Inc.
LICENSED SOFTWARE - REVERSE ASSEMBLY, REVERSE COMPILATION AND
REVERSE ENGINEERING PROHIBITED. The information contained in
this package is the proprietary property of Cadence Design Systems,
Inc., or its licensors, and may only be used in accordance with
the Cadence Design Systems license agreement under which this
package is provided.
Restricted Rights Notice to Government Users
Use duplication or disclosure by the Government is subject to
the restrictions as set forth in subparagraphs (c)(1)(ii) of the
Rights in Technical Data and Computer Software clause at
DFARS 252.227-7013. Unpublished - all rights reserved under the
copyright laws of the United States.
Cadence Design Systems, Inc.
555 River Oaks Parkway
San Jose, California 95134 USA
Located CDROM at /home/CDROM1
\c
Specify path of install directory \c
[OR type [RETURN] to exit]: \c
./LDV51
Directory ./LDV51 does not exist. Create? [y/n]: \c
y
Creating directory ./LDV51
\c
Setting up softload for lnx86 in /home/CDROM1/LDV51
\c
The following tar errors were detected:
\c
/bin/tar: 从 /home/CDROM1/IMAGES.DIR/FS.6 读入 8802 字节
/bin/tar: -b1:归档中找不到
/bin/tar: 由于前面延迟的错误而退出
Could not set up SoftLoad in /home/CDROM1/LDV51\c
You must have write permissions to install directory \c
and all its subdirectories
and atleast 10 MB available disk \c
space in install directory.
\c
Exiting
\c
发表于 2012-12-4 22:05:45 | 显示全部楼层
同求、、、、、、、、、、、、、
发表于 2013-9-9 23:46:47 | 显示全部楼层
资料不完整吧,
发表于 2013-9-10 11:04:01 | 显示全部楼层
同求、、、、、、、、、、、、、
发表于 2014-9-6 20:01:29 | 显示全部楼层
安装目录要有权限读写
GMT+8, 2025-10-8 18:19 , Processed in 0.012700 second(s), 3 queries , Gzip On, Redis On.
