查看: 30891|回复: 58
【分享】一些ipcore资料
发表于 2009-6-14 16:27:08 | 显示全部楼层 |阅读模式
有兴趣可找我。私下联系。 MSN: microcrk{at}gmail.com
诚心交流,想骗资料的就不要来了。
基本列表如下(没有的也可以问我):
mjpeg
2D FIR Filter
2D Median Filter
8B10B Encoder/Decoder
Alpha Blending Mixer
ASI
CIC Compiler
Color Space Converter
CRC Compiler
Chroma Resampler
DDR & DDR2 SDRAM Controller
DDR SDRAM High Performance Controller
DDR2 SDRAM High Performance Controller
Deinterlacer
FFT/IFFT
FIR Compiler
Gamma Corrector
HyperTransport
Line Buffer Compiler
NCO Compiler
Nios II Embedded Processor
PCI Compiler
PCI Express Compiler
POS-PHY Level 2 & 3 Compiler
POS-PHY Level 4
QDRII SRAM Controller
RapidIO
Reed-Solomon Compiler (Decoder & Encoder)
RLDRAM II Controller
HD/SD SDI
Scaler
SDI (Serial Digital Interface) v1.0.0
SerialLite II
Triple Speed Ethernet
UTOPIA Level 2 Master
UTOPIA Level 2 Slave
Viterbi Compiler
mp3/mpeg2
8/16/32/64 RISC Micro CPU
Generic Peripheral User Guide PDF
UART 1.3
SPI Interface (Master and Slave)
Real Time Clock
Advanced Audio Codec Interface
PS2 compatible Keyboard / Mouse Interface
GPIO
DMA Controller
Single Master DMA Controller
STATIC MEMORY CONTROLLER
Synchronous Static Memory Controller
Colour LCD Controller (r1p2)
Color LCD Controller
Smart Card Interface
DC-DC Converter Interface
SDRAM Controller
MultiPort Memory controller
MultiPort Memory Controller
Multi-Port Memory Controller
MultiMedia Card Interface
Vectored Interrupt Controller
External Bus Interface
CPU AHB Wrapper
AMBA Design Kit
AES
pci_m64ahb
r8051xc
C_UART
C16450 Universal Asynchronous Receiver/Transmitter
C16550 Universal Asynchronous Receiver/Transmitter with FIFOs
C165X RISC Microcontroller
C2901 4-Bit Microprocessor Slice
C2910A Microprogram Controller
C29116A 16-bit Microprocessor
C32025 Digital Signal Processor
C68000 Microprocessor
C6850 Asynchronous Communications Interface Adapter
C8051 Microcontroller Unit
C8237 Programmable DMA Controller
C8250 Universal Asynchronous Receiver/Transmitter
C8251 Programmable Communication Interface
C8254 Programmable Interval Timer/Counter
C8255A Programmable Peripheral Interface
C8259A Programmable Interrupt Controller
C8279 Programmable Keyboard/Display Interface
CUSB USB Function Controller
CZ80CPU Processor
CZ80CTC Programmable Counter-Timer
CZ80PIO Programmable Parallel Input/Output Controller
D80530 Microcontroller
DES Cryptoprocessor ECB Version
3DES Triple DES
I2C Bus Controller
r8051 Microcontroller
R80515 Microcontroller
SDLC Controller
CPXP-EPX1 – X1/X4 PCI Express Endpoint Controller Core
CPXP-EX4P – X1/X4 PCI Express Endpoint Controller Core
CUSB2 – Hi Speed USB Device Controller Core
USBHS-OTG-MPD – Hi-Speed On-The-Go Multiple Device Controller Core
I2C – Philips Serial Bus Interface Core
MAC – 10/100 Ethernet Media Access Controller Core
MAC-1G – 1 Gigabit Ethernet Media Access Controller Core
JPEG-E – Baseline JPEG Encoder Core
JPEG-D – Baseline JPEG Decoder Core
LJPEG-E - Lossless JPEG Encoder
LJPEG-D - Lossless JPEG Decoder
JPEG2000-E - JPEG2000 Encoder
JPEG2k-E - JPEG2k Encoder
SDR-SDRAM-CTRL – Single Data Rate Mobile SDRAM Controller Core
H16450S – UART with Synchronous CPU Interface Core
H16550S – UART with FIFOs and Synchronous CPU Interface Core
H16750S – UART with FIFOs, IrDA Interface, and Synchronous CPU Interface Core
PIP-AMBA – Platform IP for ARM? AMBA AHB and APB Buses, includes all the following cores
SOC-BUS-AHB – AHB Bus Core (includes socAhbBus, socAhbClkBus, socAhbRstBus, socAhbDataMux, and socAhbDecRemap)
SOC-BUS-APB – APB Bus Core (includes socApbBus, socApbClkBus, socApbRstBus, socApbDataMux, and socApbDec)
SOC-ApbBridge-AHB – AMBA AHB to APB Bridge Core (socEBI)
SOC-EBI-AHB – External Bus Interface Core (socGPIO)
SOC-GPIO-AHB – General Purpose I/O Core
SOC-SRAMCtrl-AHB – internal Synchronous SRAM Controller Core (socIntMemIF and socSSRam)
SOC-IntrCtrl-AHB – Interrupt Controller Core (socIntrCtrl)
SOC-ParPort-APB – Parallel-Printer Port Core (socParPort)
SOC-PWM-APB – Pulse Width Modulator Core (socPwm)
SOC-Timer-APB – Counter-Timer Core (socTimer)
SOC-UART-APB-APB – 16450/16550 Compatible UART Core (socUart)
SOC-Wdog-APB – Watchdog Timer Core (socWDTimer)
H264 1080p Encoder
H264 1080p Decoder
8/16/32/64 DSP
Bluetooth Controller
IEEE 1284 Host Parallel Port
Real Time Clock
Enhanced Uart with FIFOs
Uart with Synchronous Interface
m16c450/m16550a Extension
UART
Floppy Disk Controller
Microcontroller
Microcontroller with OCI
8-bit Microcontroller
IDE Controller
PCMCIA Card Interface Control
4-Channel DMA Controller
IDE Controller
3 Channel Counter-Timer
Parallel Peripheral Interface
Interrupt Controller--Engineering release
IDE Controller
SCSI Interface
Enhanced Serial Communications Controller
CAN Controller
Digital Data Separator for Floppy Disk and Tape Drives
Floppy disk Controller
I2C Bus Interface
I2C Bus Interface with VCI interface
PCI Master/Target
Full Speed USB Controller
Low Speed USB Controller
High Speed USB 2.0 Controller
High Speed USB 2.0 Controller OPB
USB OTG Controller
High Speed USB OTG Controller
USB 2.0 Multi-Point OTG Controller
USB Software Stack
USB 2.0 PHY with charge pump
USB 2.0 PHY no charge pump
Triple Speed MAC FIFO Interface
Reduced Gigabit MII module for Ethernet MAC
10 Gigabit FIFO Memory Interface for Ethernet MAC
10 Gigabit Ethernet MAC
10/100 Dual Speed Ethernet MAC
10/100/1Gig Triple Speed Ethernet MAC
Clock Domain Interface
ENDEC Interface for Ethernet MAC
Register Based Statisitic module for Ethernet MAC
PMD Interface for Ethernet MAC
Reduced MII Interface module for Ethernet MAC
Station Address Logic module for Ethernet MAC
Serial MII Interface module for Ethernet MAC
10 Bit Interface for Ethernet MAC
Serial GMII Interface module for Ethernet MAC
AHB Bridge Interface for Ethernet MAC w/FIFO
10/100 FIFO Interface
10 Gigabit PCS Base-R layer
10 Gigabit XAUI interface
Concatenated encoder/decoder
Discrete Cosine Transform
Fast Fourier Transform
Linear phase FIR
Interleaver/Deinterleaver
Numerically Controlled Oscillator
QAM/QPSK Demodulators
QAM/QPSK Modulators
Recursive Running Sum Comb Filter
Reed-Solomon encoders/decoders
Trellis decoder
Viterbi encoder/decoder
Multi-Channel DMA Controller
Direct Digital Synthesiser
DES Encryption Core
DES Encryption Processor
Multi-Function DES Core
DTMF Transceiver
E1 Deframer
E1 Framing/deframing Reordering kit
E1 Framing/Deframing kit (Selective)
FISPbus Foundation Library
FISPbus External Memory Interface
G.711 Compression
G.711 Expansion
G.726 ADPCM compact core, Single channel
G.726 ADPCM compact core, Multi-channel
G.726 ADPCM core, Low Power, Single channel
G.726 ADPCM core, Low Power, Multi-channel
GCI Interface
Single Channel HDLC Core
Single channel HDLC with FIFO
Multi-Channel hdlc controller
Basic Rate ISDN Interface
Linked List Access Controller
Modular Exponentiation Processor
Microprocessor Personality Module
Warp Microprocessor Personality Module
T1 Deframer
T1 Framing /Deframing kit (Re-ordering Add/Drop)
T1 Framing/deframing kit (Selective Add/Drop)
T1/E1 Framer
USART with FIFO
V.42bis Compression Engine
Voice CODEC
X50 Multiplexing Receiver
X50 Multiplexing Transmitter
Parallel IDE Device Ultra ATA w/o DMA
Parallel IDE Host Ultra ATA w/o DMA
Parallel IDE Host Ultra ATA-66 w/DMA
Parallel IDE Host Ultra ATA-133 w/RAID & DMA
Speed Select Ultra ATA-33, 66, 100, 133 w/DMA
PCMCIA Host Controller
PCMCIA Client Interface
Serial ATA Host Controller
Serial ATA Device Controller
Serial ATA Device Controller w/DMA
StorSelect-DS w/DMA
AMBA/AXI
AHB_DMAC
APB_I2C
SATA
SDRAM/DDR/DDR2/DDR3
USB1.1/2.0/2.0 OTG/PHY
UWB
PCI/PCIx
PCI Express 1.1/2.0
1394
Ethernet MAC10/100/1G/AHB
JPEG
PCI/PCIx
32-bit Initiator/Target for PCI
3GPP Downlink Chip Rate
3GPP RACH Preamble Detector
3GPP Searcher
3GPP Turbo Decoder
3GPP Turbo Encoder
3GPP2 Turbo Decoder
3GPP2 Turbo Encoder
64-bit Initiator/Target for PCI
64-bit Initiator/Target for PCI-X
802.16e CTC Decoder
802.16e CTC Encoder
Aurora
Aurora 64b66b
CAN
CPRI
DVB S2 FEC Encoder
Endpoint Block for PCI Express
Endpoint Block Plus for PCI Express
Endpoint for PCI Express
Endpoint PIPE for PCI Express
Ethernet 1000BASE-X PCS/PMA or SGMII
Ethernet Statistics
Fibre Channel Arbitrated Loop
Fibre Channel Core
FlexRay
Generic Framing Procedure
GTP Aurora
Interleaver/De-interleaver
LDPC 802 16 Encoder
MOST NIC
OBSAI
Packet Queue
Reed-Solomon Decoder
Reed-Solomon Encoder
Serial RapidIO
SPI-3 Link Layer Interface
SPI-3 Physical Layer Interface
SPI-4.2
SPI-4.2 Lite
Ten Gigabit Ethernet MAC
Tri Mode Ethernet MAC
Viterbi Decoder
Vlynq
XAUI
发表于 2009-9-25 15:26:56 | 显示全部楼层
你还真多啊
SDRAM 现在正在搞 有点不着边际
发表于 2009-10-24 21:12:59 | 显示全部楼层
没有MSN咋办。 1# trf564e
发表于 2009-11-17 02:38:20 | 显示全部楼层
1# trf564e
Thankssssss
发表于 2009-11-17 02:39:51 | 显示全部楼层
thanksssssssssssss
发表于 2009-11-17 08:37:03 | 显示全部楼层
goooood!
发表于 2009-11-19 21:22:03 | 显示全部楼层
很强大呀。。。
发表于 2010-1-6 16:57:21 | 显示全部楼层
太好了
发表于 2010-1-6 21:00:07 | 显示全部楼层
可以交流一下
发表于 2010-1-17 21:35:15 | 显示全部楼层
thanks.
GMT+8, 2025-12-19 18:13 , Processed in 0.025424 second(s), 7 queries , Gzip On, Redis On.
