查看: 2344|回复: 1
leon2 资料
发表于 2009-5-13 20:00:29 | 显示全部楼层 |阅读模式
The LEON VHDL model implements a 32-bit processor conforming to the SPARC V8
architecture. It is designed for embedded applications with the following features on-chip:
separate instruction and data caches, hardware multiplier and divider, interrupt controller,
debug support unit with trace buffer, two 24-bit timers, two UARTs, power-down function,
watchdog, 16-bit I/O port and a flexible memory controller. New modules can easily be
added using the on-chip AMBA AHB/APB buses. The VHDL model is fully synthesisable
with most synthesis tools and can be implemented on both FPGAs and ASICs. Simulation
can be done with all VHDL-87 compliant simulators.
发表于 2012-3-29 16:48:16 | 显示全部楼层
Is there Grmon for Linux
GMT+8, 2025-12-17 06:24 , Processed in 0.477680 second(s), 8 queries , Gzip On, Redis On.
