查看: 2822|回复: 4
电子专业英语新手必备词汇.
发表于 2009-2-28 10:56:55 | 显示全部楼层 |阅读模式
电子专业英语新手必备词汇.
综合词汇:
  1、 印制电路:printed circuit
  2、 印制线路:printed wiring
  3、 印制板:printed board
  4、 印制板电路:printed circuit board (pcb)
  5、 印制线路板:printed wiring board(pwb)
  6、 印制元件:printed component
  7、 印制接点:printed contact
  8、 印制板装配:printed board assembly
  9、 板:board
  10、 单面印制板:single-sided printed board(ssb)
  11、 双面印制板:double-sided printed board(dsb)
  12、 多层印制板:mulitlayer printed board(mlb)
  13、 多层印制电路板:mulitlayer printed circuit board
  14、 多层印制线路板:mulitlayer prited wiring board
  15、 刚性印制板:rigid printed board
  16、 刚性单面印制板:rigid single-sided printed borad
  17、 刚性双面印制板:rigid double-sided printed borad
  18、 刚性多层印制板:rigid multilayer printed board
  19、 挠性多层印制板:flexible multilayer printed board
  20、 挠性印制板:flexible printed board
  21、 挠性单面印制板:flexible single-sided printed board
  22、 挠性双面印制板:flexible double-sided printed board
  23、 挠性印制电路:flexible printed circuit (fpc)
  24、 挠性印制线路:flexible printed wiring
  25、 刚性印制板:flex-rigid printed board, rigid-flex printed board
  26、 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
  27、 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
  28、 齐平印制板:flush printed board
  29、 金属芯印制板:metal core printed board
  30、 金属基印制板:metal base printed board
  31、 多重布线印制板:mulit-wiring printed board
  32、 陶瓷印制板:ceramic substrate printed board
  33、 导电胶印制板:electroconductive paste printed board
  34、 模塑电路板:molded circuit board
  35、 模压印制板:stamped printed wiring board
  36、 顺序层压多层印制板:sequentially-laminated multilayer
  37、 散线印制板:discrete wiring board
  38、 微线印制板:micro wire board
  39、 积层印制板:buile-up printed board
  40、 积层多层印制板:build-up mulitlayer printed board (bum)
  41、 积层挠印制板:build-up flexible printed board
  42、 表面层合电路板:surface laminar circuit (slc)
  43、 埋入凸块连印制板:b2it printed board
  44、 多层膜基板:multi-layered film substrate(mfs)
  45、 层间全内导通多层印制板:alivh multilayer printed board
  46、 载芯片板:chip on board (cob)
  47、 埋电阻板:buried resistance board
  48、 母板:mother board49、 子板:daughter board
  50、 背板:backplane
  51、 裸板:bare board
  52、 键盘板夹心板:copper-invar-copper board
  53、 动态挠性板:dynamic flex board
  54、 静态挠性板:static flex board
  55、 可断拼板:break-away planel
  56、 电缆:cable
  57、 挠性扁平电缆:flexible flat cable (ffc)
  58、 薄膜开关:membrane switch
  59、 混合电路:hybrid circuit
  60、 厚膜:thick film
  61、 厚膜电路:thick film circuit
  62、 薄膜:thin film
  63、 薄膜混合电路:thin film hybrid circuit
  64、 互连:interconnection
  65、 导线:conductor trace line
  66、 齐平导线:flush conductor
  67、 传输线:transmission line
  68、 跨交:crossover
  69、 板边插头:edge-board contact
  70、 增强板:stiffener
  71、 基底:substrate
  72、 基板面:real estate
  73、 导线面:conductor side
  74、 元件面:component side
  75、 焊接面:solder side
  76、 印制:printing
  77、 网格:grid
  78、 图形:pattern
  79、 导电图形:conductive pattern
  80、 非导电图形:non-conductive pattern
  81、 字符:legend
  82、 标志:mark
电子专业英语新手必备词汇.txt.rar
16.75 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
电子200809.rar
14.61 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
pcb 词汇
发表于 2009-2-28 11:12:36 | 显示全部楼层
不错的,顶一下看看
发表于 2015-3-2 10:15:13 | 显示全部楼层
电子专业英语新手必备词汇
发表于 2015-4-7 16:52:23 | 显示全部楼层
谢谢分享。
发表于 2015-4-7 16:57:54 | 显示全部楼层
謝謝樓主分享
GMT+8, 2025-11-1 12:39 , Processed in 0.018491 second(s), 6 queries , Gzip On, Redis On.
