查看: 16458|回复: 25
求书《Static and Dynamic Performance Limitations for High Speed D/A Converters》
发表于 2008-11-23 14:51:26 | 显示全部楼层 |阅读模式
About this book
Static and Dynamic Performance Limitations for High Speed D/A Converters discusses the design and implementation of high speed current-steering CMOS digital-to-analog converters.
Starting from the definition of the basic specifications for a D/A converter, the elements determining the static and dynamic performance are identified. Different guidelines based on scientific derivations are suggested to optimize this performance. Furthermore, a new closed formula has been derived to account for the influence of the transistor mismatch on the achievable resolution of the current-steering D/A converter. To allow a thorough understanding of the dynamic behavior, a new factor has been introduced. Moreover, the frequency dependency of the output impedance introduces harmonic distortion components which can limit the maximum attainable spurious free dynamic range. Finally, the last part of the book gives an overview on different existing transistor mismatch models and the link with the static performance of the D/A converter.
Static and Dynamic Performance Limitations for High Speed D/A ConvertersSeries: The Springer International Series in Engineering and Computer Science , Vol. 761
van den Bosch, Anne, Steyaert, Michiel, Sansen, Willy M.C.
2004, 230 p., Hardcover
ISBN: 978-1-4020-7761-6
http://books.google.com/books?hl=en&id=zD4OSw_w1kIC&dq=Static+and+Dynamic+Performance+Limitations+for+High+Speed+D/A+Converters&printsec=frontcover&source=web&ots=06H8c4TZoV&sig=ENoMIJWBr6McqeOpS-YgZ9ClvNo&sa=X&oi=book_result&resnum=1&ct=result
这个网址有详细介绍和部分章节的图片,但是一直都没有找到这本书的电子版,出版商是springer
Table of contents
Abstract. List of Symbols and Abbreviations.
1: Introduction. 1.1. Introduction. 1.2. Outline of the Research Work.
2: The D/A Converter: Functionality and Specifications. 2.1. Introduction. 2.2. The Basic D/A Converter Function. 2.3. The Characteristics of an Ideal D/A Converter. 2.4. The Performance Specifications of a D/A Converter. 2.5. The D/A Converter Specifications as a Function of the Application. 2.6. Conclusions.
3: CMOS D/A Converter Architectures. 3.1. Introduction. 3.2. The Resistor D/A Converter. 3.3. The Capacitor D/A Converter. 3.4. The Current-Steering D/A Converter. 3.5. Conclusions.
4: Static Behaviour of Current Steering D/A Converters. 4.1. Introduction. 4.2. Modelling of the Random Errors. 4.3. Modelling of the Systematic Errors. 4.4. Conclusion.
5: Dynamic Behaviour of Current Steering D/A Converters. 5.1. Introduction. 5.2. Major Contibutors. 5.3. SFDR-Bandwidth Limitations. 5.4. SFDR-Bandwidth Optimised Implementations. 5.5. Conclusion.
6: A Design Methodology for High Performance CMOS Current Steering D/A Converters. 6.1. Introduction. 6.2. Determining the Level of Segmentation in a Current Steering D/A Converter. 6.3. Architectural Choice of the Thermometer Decoder. 6.4. Design of the Synchronised Switch Driver. 6.5. Dimensioning the Unit Current Cell. 6.6. Conclusion.
7: Realisations. 7.1. Introduction. 7.2. High Accuracy D/A Converters. 7.3. High Speed D/A Converters. 7.4. High Speed, High Accuracy D/A Converters. 7.5. Low Power, High Speed D/A Converters. 7.6. Overview of Realised DACs. 7.7. Comparison with Literature. 7.8. Conclusion.
8: Transistor Mismatch: Evolution and Relevance. 8.1. Introduction. 8.2. Model of Lakshmikumar. 8.3. Model of Pelgrom. 8.4. Other Models. 8.5. Mismatch Parameters for the 0.5 and the 0.4 &mgr;m CMOS Technology. 8.6. Transistor Mismatch Dependency on its Geometry. 8.7. Influence of the Surroundings of the Transistors on the Mismatch Behaviour. 8.8. The CMOS Current Steering D/A Converter as a Test Structure for Transistor Mismatch Parameter Extraction. 8.9. Conclusion.
Appendix 1: Appendix 2: Bibliography.
有哪位高手如果能找到这本书,望能给我发一份,非常感谢!!!!!
dzdy168@163.com
发表于 2009-4-21 11:55:35 | 显示全部楼层
eetop
在学校图书馆见过,130美金,看来只能复印了~~
发表于 2009-4-26 13:21:16 | 显示全部楼层
发表于 2009-6-8 23:47:58 | 显示全部楼层
Thanks for sharing,
发表于 2009-6-9 11:15:34 | 显示全部楼层
上面那个连接 页数不全
呵呵
发表于 2009-6-9 19:41:53 | 显示全部楼层
thanks for sharing
发表于 2009-6-11 11:47:38 | 显示全部楼层
这书咋样?有人读过么?
发表于 2009-6-12 12:30:02 | 显示全部楼层
我挺喜欢. 对current steering DAC分析的挺透彻.
发表于 2009-6-12 12:32:01 | 显示全部楼层
不过有几页不全,看的心里挺痒痒.弄全就好了.
发表于 2009-6-12 16:00:18 | 显示全部楼层
Steyaert和Sansen出版
值得信赖
GMT+8, 2025-12-29 19:25 , Processed in 0.058041 second(s), 7 queries , Gzip On, Redis On.
