查看: 3464|回复: 8
一种低噪声高线性超宽带单片放大器的设计
发表于 2008-6-13 12:28:59 | 显示全部楼层 |阅读模式
Low noise high linearity ultra broadband monolithic amplifier using travelling-wave gain stages
Abstract — A 2-20 GHz two-cascaded dual stage MMIC
distributed amplifier (2-CDSDA) is presented in this paper.
It consists of two cascaded dual-stage distributed amplifiers
in order to achieve flat gain, good terminal match, low noise
figure and high output power level. The topology of this
amplifier joins the best features of the conventional
distributed amplifiers and the cascaded distributed
amplifiers. The measured small signal gain was 17+/-0.57 dB
from 2 to 20 GHz. A minimum noise figure of 3 dB was
achieved while a 14.9 dBm of output power was measured at
the 1-dB compression point. The amplifier has been
fabricated using the D01PH process provided by OMMIC.
The chip size is 2 x 1.5 mm2.
abbr_a7d675ff588dfd485f4770be602d3c88.pdf
688.73 KB, 下载次数: 55 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-8-29 22:27:05 | 显示全部楼层
还是沙发么
发表于 2011-11-3 23:17:28 | 显示全部楼层
做超宽带低噪放,参考下~
发表于 2012-6-18 16:46:45 | 显示全部楼层
希望是好东西,看看再说
发表于 2015-11-3 21:21:07 | 显示全部楼层
发表于 2019-3-8 22:57:58 | 显示全部楼层
好资料~
发表于 2019-3-24 12:52:51 | 显示全部楼层
发表于 2019-7-16 19:25:50 | 显示全部楼层
好资料
发表于 2021-8-18 21:01:05 | 显示全部楼层
thanks for sharing~
GMT+8, 2025-12-24 21:16 , Processed in 0.271508 second(s), 7 queries , Gzip On, Redis On.
