查看: 26994|回复: 126
华虹NEC的model &techfile 0.5u (hspice &spectre)
发表于 2008-5-1 10:05:48 | 显示全部楼层 |阅读模式
华虹NEC的model和techfile 0.5u (hspice &spectre)
model.rar
384.43 KB, 下载次数: 918 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-2 12:13:04 | 显示全部楼层
谢谢啊!!!
发表于 2008-5-2 15:01:32 | 显示全部楼层
thanks for your sharing
发表于 2008-5-2 18:25:16 | 显示全部楼层
谢谢楼主的分享
发表于 2008-5-3 10:24:59 | 显示全部楼层
xia zai guo le
头像被屏蔽
发表于 2008-5-3 12:44:04 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-5-3 15:13:48 | 显示全部楼层
good for study
发表于 2008-5-5 13:56:31 | 显示全部楼层
很好,HHNEC还是能做不少好东西的。
发表于 2008-5-5 14:14:38 | 显示全部楼层
good model card!
*              CZ6H SPICE MODEL                    *
*      FOR NORMAL TR.S, NATIVE TR.S, PNP BJTS      *
*              fd type nmos and resistance         *
*                 2003/07/03                       *
*                 VER.  2.0                        *
*           SHANGHAI HUAHONG-NEC                   *
*           CZ6H TR./PNP BJT MODEL                    *
* TR. PARAMETER FOR HSPICE LEVEL53 (BSIM3V3.2)        *
* BJT PARAMETER FOR HSPICE LEVEL1                     *
* NOTE:USE THIS MODEL WITH HSPICE VERSION 2000.4      *
*                                           99.4      *
*      DO NOT USE WITH THE OTHER VERSIONS             *
*   << HHNEC CONFIDENTIAL AND PROPRIETARY >>          *
*    IN THIS MODEL LIB CONTAINS:                       *
*    1. LIB TT                                         *
*           SS                                         *
*           FF                                         *
*           SF                                         *
*           FS                                         *
*      ( NORMAL DEVICE CORNER MODELS)                  *
*    2. LIB TT_NA                                      *
*           SS_NA                                      *
*           FF_NA                                      *
*     ( NATIVE DEVICE CORNER MODELS)                   *
*    3. LIB TT_FD                                      *
*           SS_FD                                      *
*           FF_FD                                      *
*           SF_FD                                      *
*           FS_FD                                      *
*     ( FD TYPE NMOS CORNER MODELS)                    *
*    4. LIB BIP                                        *
*      ( P+/NW/PSUB VERTICAL PNP BIPLOAR)              *
*    5. LIB RES                                        *
*      ( RESISTOR MODEL)                               *
*  IN THIS MODEL FILE, FOUR MOS MODELS, ONE            *
*  BIPOLAR MODELS ARE SUPPLIED. THEY ARE:              *
*  1. NENH    -- FOR NORMAL NMOS                       *
*  2. PENH    -- FOR NORMAL PMOS                       *
*  3. NNON    -- FOR NATIVE NMOS                       *
*  4. N_FD    -- FOR FD BUFFER NMOS                    *
*  5. PNP5    -- FOR BIPOLAR PNP4.8_13                 *
*  subckt name are list below:                         *
*       Device Name              subckt name:          *
*  FD Type NMOS:                                       *
*       FD Tr.                     nch_fd              *
*  Resistance:                                         *
*       N-well                     rnwell              *
*       N+diffusion                rndiff              *
*       P+diffusion                rpdiff              *
*       polycide                   rplcd               *
*       metal1                     rme1                *
*       metal2                     rme2                *
*       metal3                     rme3                *
*       metal4                     rme4                *
*       Rpoly                      rrpoly              *
1. CZ6H Normal MOS spice model
1.1 CZ6H target spec. (Tj=27C)
  Ln=Lp=0.54+/-0.04um
  Vtn=0.65V+/-0.1V Vtp=-0.8V+/-0.15V
  Ionn/Ionp=4.3mA/-2.2mA(Typical case)
  Tox=155+/-10A
       @Vt equals to Vgs for VDS=+/-5.0V, IDS=+/-1uA, W=50um.
       @Ion equals to IDS/5 for VDS=VGS=+/-5.0V, W=50um.
1.2 Model name
   nch model name = NENH
   pch model name = PENH
1.3 Model spec.
(1)Typical case LIB: TT
  +Ln=0um Ionn= 4.3mA Vtn= 0.65V Tox=155A
  +Lp=0um Ionp=-2.2mA Vtp=-0.80V Tox=155A
(2)Fast case LIB: FF
  +Ln=-0.04um Ionn= 4.68mA Vtn= 0.55V Tox=145A
  +Lp=-0.04um Ionp=-2.55mA Vtp=-0.65V Tox=145A
(3)Slow case LIB: SS
  +Ln=+0.04um Ionn= 3.93mA Vtn= 0.75V Tox=165A
  +Lp=+0.04um Ionp=-1.87mA Vtp=-0.95V Tox=165A
(4)VtN Low - VtP High case LIB: FS
  +Ln=0um Ionn= 4.48mA Vtn= 0.55V Tox=155A
  +Lp=0um Ionp=-2.04mA Vtp=-0.95V Tox=155A
(5)VtN High - VtP Low case LIB: SF
  +Ln=0um Ionn= 4.11mA Vtn= 0.75V Tox=155A
  +Lp=0um Ionp=-2.36mA Vtp=-0.65V Tox=155A
1.4
  Perimeter of the drain and source junctions including the channel edge
shuld be always assigned by PD and PS in the netlist as shown below.
        PD=2W+2D
                                      Poly
                         A +----------+  +----------+
                        W| |   drain  |  |  source  |
                         | |          |  |          |Diff
                         v +----------+  +----------+
                                D     ~  ~
1.5
  Area of the drain and source junctions shuld be always assigned
by AD and AS in the net list as shown below.
        AD=W*D
1.6 Minimum gate length in net list and in design rule should be assigned
Ln=Lp=0.54um.
      Lminn=Lminp=0.54um is in net list and in design rule.
      Lminn=Lminp=0.54um is on wafer.
2. CZ6H NATIVE NMOS SPICE MODEL
2.1 CZ6H Native Device target spec. (Tj=27C)
  L  = 2.4+/-0.04um Ion= 3.36mA  Vt= -0.22+/-0.05V
  Tox= 155+/-10A
          @Ion equals to IDS/5 for VDS=VGS=5V, W=50um.
          @Vt equals to Vgs for VDS=5V, IDS=1uA, W=50um.
2.2 Model name
   model name = nnon
2.3 Model spec.
(1)Typical case
  LIB name: TT_NA
  L+=0.00um  W+=0.00um  Tox+=0A  Vt+=0V  Ion=3.36mA
(2)Fast case
  LIB name: FF_NA
  L+=-0.04um  W+=+0.12um  Tox+=-10A  Vt+=-0.05V
(3)Slow case
  LIB name: SS_NA
  L+=+0.04um  W+=-0.12um  Tox+=+10A  Vt+=+0.05V
2.4
should be always assigned by PD and PS in the net list as shown below.
        PD=2W+2D
                                       ____Poly
                            ___________|  |___________
                         W |    drain  |  |   source  |
                           |___________|  |___________|Diff
                                 D     |  |
2.5
  Area of the drain and source junctions should be always assigned
        AD=W*D
3. PNP Parasitic BJT
     The model parameters are extracted based on the pattern which
   emitter(P+) area is 4.8*4.8um2 and Base(Nwell) area is 9.12*9.12um2.
3.1 LIB and Model Name:
     LIB: BIP
     MODEL: PNP5
3.2 Model usage:
   Temperature range: -40~125
   This model only applies to the PNP device with fixed size shown above.
   This model only applies to the PNP device on CZ6 series Processes.
4. CZ6H FD TYPE NMOS SPICE MODEL
4.1.CZ6H FD TYPE NMOS target spec. (Tj=23C)
    Ln=0.81+/-0.04um   Tox=155+/-10A
4.2.Model name : none
      (Please use the subckt : nch_fd)
4.3.Subckt name : nch_fd
   sample :
       .LIB TT_FD
       x1 drain gate source sub nch_fd
       +wn=50u adn='2.46u*(wn+1.02u*2) pdn='2.46u*2+(wn+1.02u*2)'
       +asn='1.83u*wn' psn='1.83u*2+wn*2'
       The wn  is channel width of FD buffer.
       The adn is nwell area          in drain of FD buffer.
       The pdn is nwell perimeter     in drain of FD buffer.
       The asn is Diffusion area      in source of FD buffer.
       The psn is diffusion perimeter in source of FD buffer.
4.4.Model spec.
(1)Typical case
  LIB name: TT_FD
  Ln=0.81um, delta L= 0.00um, delta Vt= 0.0V, Tox=155A
(2)Fast case
  LIB name: FF_FD
  Ln=0.81um, delta L=-0.04um, delta Vt=-0.1V, Tox=145A
(3)Slow case
  LIB name: SS_FD
  Ln=0.81um, delta L= 0.04um, delta Vt= 0.1V, Tox=165A
(4)Nch Low - Pch High  case
  LIB name: FS_FD
  Ln=0.81um, delta L= 0.00um, delta Vt=-0.1V, Tox=155A
(5)Nch High - Pch Low  case
  LIB name: SF_FD
  Ln=0.81um, delta L= 0.00um, delta Vt= 0.1V, Tox=155A
5. Resistor Model usage:
   Please use subckt
发表于 2008-5-5 14:34:01 | 显示全部楼层
不知道HHNEC的DM-CZ6H-0024-021的工艺代表的事什么?
手机版| 小黑屋| 关于我们| 联系我们| 用户协议&amp;隐私声明| 版权投诉通道| EETOP 创芯网
GMT+8, 2025-12-31 03:31 , Processed in 0.024920 second(s), 7 queries , Gzip On, Redis On.
