查看: 7486|回复: 20
model PLL in PrimeTime
发表于 2008-4-8 17:33:23 | 显示全部楼层 |阅读模式
Modeling the behavior of  PLLs in PrimeTime
model PLL in PrimeTime.pdf
482.08 KB, 下载次数: 139 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-2 00:23:02 | 显示全部楼层
发表于 2008-8-6 17:25:55 | 显示全部楼层
这么好的东西,太感谢了
发表于 2008-8-6 17:26:55 | 显示全部楼层
请问楼主,这是专门针对PLL的PT constraint吗?
 楼主| 发表于 2008-8-6 21:45:21 | 显示全部楼层
This paper discusses basic modeling techniques for PLLs, duty cycle modeling, jitter and skew, and on-chip-variation effects.
1 Introduction........................................................................................................................3
2 The basic insertion delay cancellation (idc) PLL................................................................... 4
2.1 The problem – too muchdelay......................................................................................................................4
2.2 The solution – the insertion delay cancellationPLL......................................................................................5
2.3 Timing the basic idc PLL in PrimeTime.......................................................................................................6
2.4 The IDC multiplier PLL.............................................................................................................................15
2.5 The PLL model itself.................................................................................................................................24
2.6 Performance considerations........................................................................................................................25
3 Duty Cycle........................................................................................................................26
3.1 Internal clocks (other thanPLLs)................................................................................................................26
3.2 Primary input clocks and PLLs...................................................................................................................28
3.3 Applying this to our multiplier pllcircuit....................................................................................................35
3.4 When to use thesetechniques.....................................................................................................................41
4Jitter.................................................................................................................................42
4.1 Jitter, skew, anduncertainty.......................................................................................................................42
4.2 My definition ofjitter.................................................................................................................................42
4.3 Sources ofjitter..........................................................................................................................................43
4.4 Effects of jitter on different sorts ofpaths....................................................................................................43
4.5 Modeling jitter withset_clock_uncertainty..................................................................................................47
4.6 Applying jitter specs to the example circuit – simple case...........................................................................47
4.7 Generatedclocks........................................................................................................................................54
4.8 What about fallingedges?..........................................................................................................................56
4.9 Applying jitter specs to the example circuit – complex case........................................................................57
5 On-chipVariation..............................................................................................................64
5.1 The classic OCV case................................................................................................................................64
5.2 EnterCRPR...............................................................................................................................................67
5.3 OCV and PLLs..........................................................................................................................................69
5.4 The OCV/PLL excess pessimismproblem...................................................................................................75
6 OCV/PLL excess pessimism workarounds......................................................................... 79
6.1 Forcing OCV off on the fbpath...................................................................................................................79
6.2 Referencing the i/os to the feedbackclock...................................................................................................96
6.3 The shell game........................................................................................................................................105
7Conclusion.....................................................................................................................111
8 Acknowledgements ......................................................................................................... 112
9 References......................................................................................................................113
10Appendix.....................................................................................................................114
10.1 The PLL model itself..............................................................................................................................114
发表于 2008-10-29 02:01:27 | 显示全部楼层
goood
发表于 2008-10-29 08:57:09 | 显示全部楼层
感謝分享
感謝分享
正好在學dc
发表于 2008-12-15 10:48:47 | 显示全部楼层
dddddddddddddddddd
发表于 2008-12-17 09:22:58 | 显示全部楼层
好东西
谢谢楼主
发表于 2009-3-3 08:22:23 | 显示全部楼层
谢谢了!!!
GMT+8, 2025-10-29 07:33 , Processed in 0.024378 second(s), 7 queries , Gzip On, Redis On.
