查看: 60509|回复: 155
[原创] Xcelium/Jaspergold License
发表于 2019-4-19 00:48:37 | 显示全部楼层 |阅读模式
Hello everyone,
I am sharing the latest platform version of the Xcelium license (it also works with older versions).
First, generate a FlexLM license using lmcrypt. These are the characteristics of Xcelium:
Xcelium_Limited_Single_Core
XceliumLimitedSingleCoreLegacy
Xcelium_Single_Core_Legacy
Xcelium_Safety
Xcelium_Multi_Core
Xcelium_For_Partners
Then, use sfk to patch the file.
  1. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">-bin / 41574989ff4156415541544989cc55534489c34881ecf80000004889742420be140000008954241c4c894c24108bac2438010000c78424ec00000000000000e8 / 31c0c389ff4156415541544989cc55534489c34881ecf80000004889742420be140000008954241c4c894c24108bac2438010000c78424ec00000000000000e8 / -bin / 41574989ff415641554154554889cd534489c34881ec08010000488b87900200004889742428be14000000895424244c894c2418488b80381e0000448ba0300600004585e4440f44a42448010000e8 / 31c0c389ff415641554154554889cd534489c34881ec08010000488b87900200004889742428be14000000895424244c894c2418488b80381e0000448ba0300600004585e4440f44a42448010000e8 /</font></font>
    复制代码
Please enjoy
  1. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Loading snapshot worklib.test:sv .................... Done </font></font>
  2. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">xmsim: *W, DSEM2009: This SystemVerilog design is simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics. </font></font>
  3. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">xcelium> source ../Titan/Cadence/XCELIUM/XCELIUM1903/tools/xcelium/files/xmsimrc </font></font>
  4. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">xcelium> run </font></font>
  5. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Xcelium test </font></font>
  6. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">xmsim: *W,RNQUIE: Simulation is complete. </font></font>
  7. <font style="vertical-align: inherit;"><font style="vertical-align: inherit;">xcelium > exit</font></font>
    复制代码
I didn't explain all the reasons, so you may need to search for other posts here just in case.
Use it only for evaluation purposes, if you plan to do something that generates revenue, buy it from Cadence.
Float_Cadence_LicGen_xcelium.tar
618.85 KB, 下载次数: 2510 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Licgen
发表于 2019-4-19 08:02:48 | 显示全部楼层
非常感谢!
发表于 2019-4-19 08:47:46 | 显示全部楼层
非常感谢!
发表于 2019-4-19 09:07:42 | 显示全部楼层
RE: Xcelium/Jaspergold License [
发表于 2019-4-20 13:05:28 | 显示全部楼层
great
发表于 2019-4-20 13:08:51 | 显示全部楼层
great
发表于 2019-4-21 18:56:02 | 显示全部楼层
thanks
发表于 2019-4-22 08:38:47 | 显示全部楼层
需不需要启动lmgrd?
发表于 2019-4-22 09:10:39 | 显示全部楼层
对于INCISIV 把SERVER、DAEMON和USE_SERVER这三行去掉后 可以不需要启动lmgrd
但是XCELIUM 去掉三行后报-8的错误 如果保留那三行启动lmgrd 会报-97的错误
请大神帮忙看一下
发表于 2019-4-22 09:32:49 | 显示全部楼层
MARK 一下
GMT+8, 2025-9-30 03:11 , Processed in 0.018733 second(s), 4 queries , Gzip On, Redis On.
