在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4984|回复: 6
[求助] 請問,在verilog中,不常見的冒號(已解決)
发表于 2013-3-26 16:36:11 | 显示全部楼层 |阅读模式
以下是我有疑問的code片段(標上藍色)
always @(sort_loSort_merge_loMerge_comp_0_a1, sort_loSort_merge_loMerge_comp_0_a2) begin: ARRAY8SORTER_SORT_LOSORT_MERGE_LOMERGE_COMP_0_LOGIC
    sort_loSort_merge_loMerge_loMerge_feed_a <= sort_loSort_merge_loMerge_comp_0_a1;
    sort_loSort_merge_loMerge_hiMerge_feed_a <= sort_loSort_merge_loMerge_comp_0_a2;
    if ((1 == (sort_loSort_merge_loMerge_comp_0_a1 > sort_loSort_merge_loMerge_comp_0_a2))) begin
        sort_loSort_merge_loMerge_loMerge_feed_a <= sort_loSort_merge_loMerge_comp_0_a2;
        sort_loSort_merge_loMerge_hiMerge_feed_a <= sort_loSort_merge_loMerge_comp_0_a1;
    end
end
這段code在編譯的過程是沒有錯誤的,只是好奇為什麼這裡的begin後面可以加一個冒號,這個冒號又代表什麼意思?
是把後面這一整段命名成ARRAY8SORTER_SORT_LOSORT_MERGE_LOMERGE_COMP_0_LOGIC  ?
发表于 2013-3-26 17:26:20 | 显示全部楼层
那个是块名
发表于 2013-3-26 22:12:45 | 显示全部楼层
卷标 方便debug和DC
发表于 2013-3-27 23:48:50 | 显示全部楼层
楼主你答对了....
begin end块是可以加块命的
发表于 2013-3-28 15:52:34 | 显示全部楼层
Both sequential and parallel blocks can be named by adding a name after the keywords begin or fork.
发表于 2013-3-28 16:55:59 | 显示全部楼层
begin/end 块是可以命名的
 楼主| 发表于 2013-3-30 16:47:51 | 显示全部楼层
謝謝各位
GMT+8, 2025-2-11 02:15 , Processed in 0.026067 second(s), 8 queries , Gzip On, Redis On.
