楼主: JoyShockley
[求助] 开关管长度的设计如何考量?
发表于 2013-11-12 13:49:32 | 显示全部楼层
I see little point to optimize the switch size for DCCA in VCO.  It looks funny if your purpose is just to have a larger effective C.
Have you checked whether your equation is correct enough to calculate the effective capacitor when using Port(it is frequency related) ?
if you know Ron/Coff of the switch(Q value, tuning range),  it is good enough for a DCCA design.
 楼主| 发表于 2013-11-12 13:54:13 | 显示全部楼层
回复 11# wfcawy
   5GHz SP 仿真
   把L 调到0.5u后,即使W=5u。
   开启后接入的有效电容只有70fF,而MIM电容大小是158fF。假设我希望能接入100fF,我应该调节MIM吗?
发表于 2013-11-12 14:19:09 | 显示全部楼层
the imaginary part of Y11 is not purely capacitance, and it is better for you to  make some derivation on imag(Y11) based on the first order assumption of the switch (on: Ron,Con, off: Roff, Coff). it is very helpful to design a reasonable DCCA in an intuitional  way
发表于 2013-11-12 14:22:48 | 显示全部楼层
回复 12# JoyShockley
    70fF is due to the larger Ron, you need to reduce Ron by increase W, usually the Coff is OK to be about 1/10 of Cmim
发表于 2013-11-12 20:29:38 | 显示全部楼层
回复 4# kwankwaner
    dibl...
发表于 2013-12-2 16:49:30 | 显示全部楼层
回复 3# JoyShockley
    L越大,VT越大吧
发表于 2014-1-14 23:22:13 | 显示全部楼层
回复 16# jiangyanjin
It depends, for long channel devices, Vth increases as Leff increases just as the case in Razavi's textbook,
However, in modern process (i.e. 130nm or 65nm), as Leff increases, Vth increases at first and decreases at
a certain Leff point. Very interesting. This is so called RSCE effect
发表于 2014-1-15 09:57:00 | 显示全部楼层
进来学习。
发表于 2014-1-15 10:17:48 | 显示全部楼层
research
发表于 2014-1-17 19:56:44 | 显示全部楼层
抠得这么细致,学习了!
GMT+8, 2025-9-14 08:20 , Processed in 0.017580 second(s), 3 queries , Gzip On, Redis On.
