查看: 11379|回复: 31
Generate the floating lic for n0vas stuff
发表于 2012-5-17 11:41:38 | 显示全部楼层 |阅读模式
novas_lpd.zip (1.04 KB , 下载次数: 184 ) novas.zip (1.3 KB , 下载次数: 195 ) check the attachment, it's a source file which is used for ef@licgen,  you just need to copy it to 'packs', certainly, you must have the corresponding .lpd file.
Notice : if you want to generate a floating one, don't USE 'ANY' as the hostid, but the correct one which is really lic server, the license should be available for the version that is older than 2011.
You must not use it for business purpose !! Okay, enjoy it now.
postscript: perhaps , you also need the lpd file, now attach it.
发表于 2012-5-17 13:35:09 | 显示全部楼层
发表于 2012-5-18 11:53:16 | 显示全部楼层
very very good
thanks a lot
发表于 2012-5-18 12:32:57 | 显示全部楼层
有人試過,可以破解新版的Verdi 2012.01嗎?
发表于 2012-5-19 11:46:11 | 显示全部楼层
谢谢楼主
发表于 2012-5-19 11:46:20 | 显示全部楼层
good!
发表于 2012-5-21 12:53:54 | 显示全部楼层
Thanks a lot!
But didn't include the Laker_ADP feature.
发表于 2012-5-21 12:55:58 | 显示全部楼层
Thanks a lot!
发表于 2012-5-21 17:21:28 | 显示全部楼层
*ERROR* License Error: 0x3ec, Contact customer support. Program will now exit.
It is failed for Verdi 2012.01 & 2012.04.
PS. 2012.01 has patched on this forum.
      But, 2012.04 not yet.
发表于 2012-5-21 21:34:29 | 显示全部楼层
Thanks a lot!
GMT+8, 2025-8-17 11:16 , Processed in 0.020750 second(s), 6 queries , Gzip On, Redis On.
