楼主: phoenixson
Generate the floating lic for n0vas stuff
发表于 2012-11-1 21:47:56 | 显示全部楼层
一直在找 floating 的,谢谢!
发表于 2012-11-1 21:48:34 | 显示全部楼层
一直在找 floating 的,谢谢!
发表于 2012-11-1 21:51:51 | 显示全部楼层
回复 9# wilson168
    "PS. 2012.01 has patched on this forum.
      But, 2012.04 not yet."
哪里有链接?是floating的吗?
发表于 2012-11-2 21:24:04 | 显示全部楼层
    thanks! It is good for verdi, but fail for nLint. After nLint running for a few minitus, the error message occured:
*ERROR* License Error: 0x3ec, Contact customer support. Program will now exit.
发表于 2012-11-2 21:37:40 | 显示全部楼层
PS: Is there feature for SimVE and hdlin_sv and DataReplay ? thanks!
发表于 2012-11-5 16:28:12 | 显示全部楼层
经过多次尝试,确认2012版的verdi是无法正常试用的,使用十来分钟后就会报错:
其他几个feature也是同样问题,即 ES string不匹配。
发表于 2012-11-5 20:11:14 | 显示全部楼层
Notice : if you want to generate a floating one, don't USE 'ANY' as the hostid, but the correct one which is really lic server, the license should be available for the version that is older than 2011.
Do you mean the licenses generated can't be used for newer releases?
发表于 2012-11-28 21:24:21 | 显示全部楼层
多謝..多謝...
 楼主| 发表于 2012-11-29 09:28:56 | 显示全部楼层
judung 发表于 2012-11-5 20:11
maybe, I just need to modify the time limit for the new source file in order to be compatible with the new version.
发表于 2012-11-29 15:55:04 | 显示全部楼层
Thanks a lot!
GMT+8, 2025-10-30 06:54 , Processed in 0.018814 second(s), 3 queries , Gzip On, Redis On.
