查看: 6239|回复: 22
[求助] 请教,LDO设计中,调整管栅极电压怎样可以降低?
发表于 2010-11-12 10:29:04 | 显示全部楼层 |阅读模式
我最近在设计LDO,把调整管作为运放第三级,放进去仿真调试。可是发现调整管栅极电压居高不下,该如何降低调整管栅极的电压,也就是误差放大器第二级输出电压呢?
 楼主| 发表于 2010-11-12 10:32:10 | 显示全部楼层
实在是搞不懂了
发表于 2010-11-12 10:56:27 | 显示全部楼层
Could you show your schematic?
 楼主| 发表于 2010-11-12 12:11:42 | 显示全部楼层
回复 3# shiunger
    clip_image002.gif 不知能不能看清楚
 楼主| 发表于 2010-11-12 12:21:24 | 显示全部楼层
回复 3# shiunger
    谢谢啦 你真热心
发表于 2010-11-12 14:20:07 | 显示全部楼层
Why did you use common-source at your 3rd-stage?
发表于 2010-11-12 14:26:34 | 显示全部楼层
这时候有负载吗,加上负载这点电压就下来了,--假设你的电路正常工作的话。
发表于 2010-11-12 14:27:59 | 显示全部楼层
发表于 2010-11-12 15:04:17 | 显示全部楼层
Yes, we could certainly use common-source at the output stage.
I just wondered why did you use a high impedance output stage to drive a current load.
I assume the current load is low impedance.
Am I right?
Thanks!
why not??
goodsilicon 发表于 2010-11-12 14:27
发表于 2010-11-12 16:34:20 | 显示全部楼层
I just wondered why did you use a hi ...
shiunger 发表于 2010-11-12 15:04
Unfortunately, you are wrong.
since it is a closed loop, the output impedance is low at the output, at least at low frequency. So, it can work as a voltage source to drive a low impedance. Thanks!
GMT+8, 2025-9-10 20:47 , Processed in 2.190301 second(s), 6 queries , Gzip On, Redis On.
