查看: 223|回复: 5
[求助] 论文下载求助
发表于 2025-12-1 10:30:44 | 显示全部楼层 |阅读模式
悬赏150资产已解决
请帮忙下载以下论文,多谢!
A 1.5GS/s 7-bit Charge-Injection SAR ADC using a PVT-tracking 1-bit Metastability Detector
https://ieeexplore.ieee.org/document/11269846
A Calibration-Free Pipelined-SAR ADC With Cross-Stage Gain-Mismatch Error Shaping and Inherent Noise Shaping
https://ieeexplore.ieee.org/document/11236428
A Parasitic and Mismatch Tolerant Fully Common-Centroided and Shielded Split-CDAC With Identical Unit Capacitors for SAR-ADC
https://ieeexplore.ieee.org/document/11223063
An Analysis of Switch Thermal Noise in SAR Converters
https://ieeexplore.ieee.org/document/11205474
Ultra-Low-Power Dynamic-Bias Comparators With Self-Clocked Latch in 65-nm CMOS
https://ieeexplore.ieee.org/document/11185358
A 0.0106 mm2 8 nW Resistor-Less BJT Bandgap Reference Circuit in 65 nm CMOS With Orthogonal Voltage and Temperature Coefficient Trims
https://ieeexplore.ieee.org/document/11230083
Noise Modulation of a Bandgap Reference by Using a Single Resistor
https://ieeexplore.ieee.org/document/11217282
最佳答案
发表于 2025-12-1 10:30:45 | 显示全部楼层
附件如下
A_1.5GS_s_7-bit_Charge-Injection_SAR_ADC_using_a_PVT-tracking_1-bit_Metastabilit.pdf
698.33 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_Calibration-Free_Pipelined-SAR_ADC_With_Cross-Stage_Gain-Mismatch_Error_Shapin.pdf
4.19 MB, 下载次数: 10 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A_Parasitic_and_Mismatch_Tolerant_Fully_Common-Centroided_and_Shielded_Split-CDA.pdf
3.06 MB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
An_Analysis_of_Switch_Thermal_Noise_in_SAR_Converters.pdf
773.59 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Ultra-Low-Power_Dynamic-Bias_Comparators_With_Self-Clocked_Latch_in_65-nm_CMOS.pdf
9.1 MB, 下载次数: 10 , 下载积分: 资产 -4 信元, 下载支出 4 信元
A_0.0106_mm2_8_nW_Resistor-Less_BJT_Bandgap_Reference_Circuit_in_65_nm_CMOS_With.pdf
6.75 MB, 下载次数: 12 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Noise_Modulation_of_a_Bandgap_Reference_by_Using_a_Single_Resistor.pdf
3.17 MB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2025-12-1 11:31:51 | 显示全部楼层
多谢!
发表于 2025-12-1 13:40:09 | 显示全部楼层
好好
发表于 2025-12-3 09:11:06 | 显示全部楼层
多谢分享
发表于 2025-12-4 17:33:19 | 显示全部楼层
Thanks.
GMT+8, 2025-12-25 08:58 , Processed in 0.021119 second(s), 5 queries , Gzip On, Redis On.
