查看: 552|回复: 5
[求助] 12bit SAR ADC 0.5um Prcoess Size < 300x300
发表于 2025-11-7 16:44:34 | 显示全部楼层 |阅读模式
悬赏200资产未解决
Hi, All:
     12bits SAR ADC
      True is 10bits, Full Range.
       转换速率:同步clock的架构就在4 to 8 MHz.
      Calibration: NO.
      面临的问题是:
      Full Range, 0 to 3.3
      Any detail document can share it.
      First time design. No relation Database.
Thanks
发表于 2025-11-18 11:46:34 | 显示全部楼层
with or without input rail-to-rail buffer?
with:linearity limited for gnd/vrefp;
without:sampling time and input source resistance limited;
application depends
 楼主| 发表于 2025-11-19 11:18:17 | 显示全部楼层
without:samplin ...
Hi,Sir:
    Without input Rail-to Rail Buffer
    The limit is the VDD to Gnd with Good INL/DNL  with Sampling phase some clocks
    The structure is Main DAC 7 bit  (Cap array) , Sub DAC 5 bit (Resistor Ladde)
Any suggestion
Thanks
发表于 2025-11-25 17:55:22 | 显示全部楼层
mitchell0001 发表于 2025-11-19 11:18
Hi,Sir:
    The limit is the VDD to Gnd with Good INL/DNL  w ...
why choose 12bits distributed to cap and res separately?
 楼主| 发表于 2025-11-27 10:44:23 | 显示全部楼层
Reference the origin design (10bits) to extension to 12bits.
But the origin Database is not good.  So it need to enhance to 12bits for Products application.
发表于 昨天 23:48 | 显示全部楼层
7-bit main DAC + 5-bit sub DAC looks good to me.
GMT+8, 2025-12-20 16:12 , Processed in 0.014813 second(s), 3 queries , Gzip On, Redis On.
