查看: 599|回复: 0
[原创] MLCC Fabrication Process
发表于 2025-6-26 23:44:54 | 显示全部楼层 |阅读模式
MLCC fabrication process14 steps
1.       Slurry fabrication
Process of mixing dielectric ceramic powder with organic binder solution to produce a well dispersed slurry
2.       Ceramic sheet casting
Process of fabrication thin and uniform ceramic sheets by coating the slurry on PET film
3.       Inner electrode printing
Process of screen-printing the electrode paste onto ceramics sheets
4.       Stacking
Process of stacking the individual printed sheets according to the pre-determined design
5.       Lamination
Process of forming of stacked ceramic sheets into a monolithic bar by applying controlled, uniform pressure
6.       Cutting
Process by which the monolithic bar in separated into individual chips
7.       Binder burn out
Process of baking the chips in order to remove the carbon residue, temperature exceed 200C
8.       Firing
Process of sintering the chip at extremely high temperatures for full densification and satisfactory dielectric characteristics
9.       Tumbling
Process of slowly grinding the surface and edges of the chip for better electrode contact and to prevent chipping
10.    Termination dipping
Process of applying the external electrode by dipping each end of the chip
11.    Termination firing
Process of sintering the terminated chip at high temperature up to 800C, for electrical contact between the internal and external electrode
12.    Plating
Process of coating termination with a Nickel barrier layer, followed by a Tin layer for surface mounting
13.    Sorting
Process of measuring electrical characteristics such as capacity.
14.    Taping
Process of Packaging for shipment to consumer
GMT+8, 2025-9-15 08:07 , Processed in 0.011922 second(s), 3 queries , Gzip On, Redis On.
