在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 441|回复: 1
[求助] QUANTUS QRC run failed
发表于 2025-4-11 21:07:43 | 显示全部楼层 |阅读模式
在quantus所有提参完成之后 卡在“SIP 0”很长时间,无法得到extracted_view,最终aveng fork terminated abnormally,希望各位大神帮忙看看
附上log的最后部分
pax16 took  0.63 user, 0.29 sys, 1.00 elapsed, 79704.0 kbytes
INFO (PAXSXTN-142067): Forked command: PAX16 34
  pax16 took  0.52 user, 0.07 sys, 0.00 elapsed, 79684.0 kbytes
INFO (PAXSXTN-142063): Starting "SIP 0": sip
INFO (LBRCXM-610): Extraction finished.
INFO (LBRCXU-108): Starting
/data/user/wangruida/Public/opt/Cadence/ICADVM201/bin/qrcToDfII -extract both -run_name doubletail_comp_enhanced -cdlout_run_dir /data/user/wangruida/LVS -check_cell_view FALSE -device_finger_delimiter @ -extracted_view av_extracted21 -lvs_source agds -hrcx_cells_file /data/user/wangruida/LVS/svdb/doubletail_comp_enhanced/doubletail_comp_enhanced.hcl -cap_models comment -capacitor pcapacitor -resistor presistor -cap_prop_name c -res_prop_name r -transfer_net_expression TRUE -extview_tmp /data/user/wangruida/LVS/svdb/doubletail_comp_enhanced/extview.tmp -run_dir /data/user/wangruida/LVS/svdb/doubletail_comp_enhanced -cdslib /data/user/wangruida/cds.lib -lib_name asychronousSAR -cell_name doubletail_comp_enhanced -view_name layout1 -extview_rul /data/user/wangruida/LVS/svdb/doubletail_comp_enhanced/extview.rul -server /data/user/wangruida/Public/opt/Cadence/QUANTUS212/tools.lnx86/extraction/bin/64bit//../shapeServer
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.12s.
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@1"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@2"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@3"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@4"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@5"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@6"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@7"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@8"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@9"
INFO (LBCLV-5347): spice2db warning: Duplicate dev "MM14" in cell "doubletail_comp_enhanced" renamed "MM14@10"
device nch_ulvt_mac M nuvgate_mac_sf nch_ulvt_mac ivpcell tsmcN28 D G S B
Initializing from libInit.il for library tsmcN28...
   --  tsmcPdkParamTable.il
   --  load_apc_tsmc_n28.il
   --  apc_util.cdn
   --  tsmcN28.pce
   --  tsmcLDEparamTable.il
   --  cniUtils_encrypted.il
   --  tsmcN28_CB_2.cxt
   --  tsmcN28_updateCDFs.cxt
   --  metalRES.cxt
   --  tsmcN28.cxt
   --  tsmcN28_CB_3.cxt
   --  tsmcN28_CB_4.cxt
   --  tsmcN28Tool.cxt
   --  tsmc_LDE.cxt
   --  tsmcN28_gateCB.cxt
   --  tsmcDNA_utility.cxt
   --  tsmcN28_CB_1.cxt
   --  tsmcN28_tif.cxt
Loading Working place Display File '/data/user/wangruida/display.drf'
*****  aveng fork terminated abnormally  *****
发表于 2025-5-8 18:35:04 | 显示全部楼层
这个前面应该就错了
GMT+8, 2025-7-5 13:45 , Processed in 0.013745 second(s), 9 queries , Gzip On, MemCached On.
